Beginner
Re: Output drop
Hi Salem,
Did you implement all the advised solutions if not please go ahead and implement those and then update us with the output?
However, if you need additional help with regards to your case I suggest you open a TAC Case and share "Show Tec" output with them.
BR,
Tayyab - www.tayyabmunir.com
***Please rate if response was helpful***
*** Please rate all helpful responses and mark solutions***
Everyone's tags (2)
Beginner
Re: Output drop
Hello @TAYYAB MUNIR
May I ask you to answer my previous post please ?
I'm going to make sure before implementing the solution .
Beginner
Re: Output drop
Hi @salemmahara
Yes you can?
Beginner
Re: Output drop
hank you @TAYYAB MUNIR
I mean my last reply in page 1 ( I replayed your post ) .
Could you please check and confirm it if it's okay . I asked you some questions there
Beginner
Re: Output drop
@salemmahara
1) Output drop rate is : (562303015  / 410883103982) * 100 = 0.13% which means reasonable (Less than 1 percent) or (562303015  /410883103982) * 1000 = 1.3 packet within 1000 .
So, the actual drop rate is around is less than 1 percent which is quite low, that these drops happened on a non-priority queue.
2) By applying the command Qos queue-softmax-multiplier 600we will increase the buffer size multiplied by 6 which means 300*6*256= 450KB for each interface. Right ? Does it effect on TenGig interfaces too? I have some TenGig interfaces which are working fine with their buffer size without any drop.
 Since all ports of the Catalyst 3850 use a shared-buffer on as needed-basis, I thought it could be a problem to change the soft-buffer value to the maximum of 1200 and 1200 maximum buffer size often add latency to the packets. So initially increase to 600.
conf t
qos queue-softmax-multiplier 600
Does this command need reload?
Reload required for release 3.6.6E and 3.7.5E in your case you’re running code 3.6.8 after increasing the soft-buffer take effect immediately.
 3) When we analyze the graphs, no interfaces touch the maximum BW . So why a 1G interface fails to transfer 30-40Mb data with output drop? Only because of that we are using them as uplink (One to many)? But 3850 series are supposed to be used in aggregation layer! Even at core in environments with lower data rate.
Its a bug and fixed release already in place.
BTW , I want to share another thing with you . Our 3850s are connected to downstream switches which their uplink ports are SFP+ but we use GLC-T(1G) for converting Fibber to copper . But I think it doesn't effect the output drop. I have similar experience in other projects without any output drop. What is your idea ?
Bug triggered on this device, other devises still not hit the bug!!!
*** Please rate if response helpful***
Beginner
Re: Output drop
Hello @TAYYAB MUNIR
I changed the softmax-buffer and cleared all counters.
It needs 1-2 days to monitor the switch. I'll send the result as soon as possible
Thank you so much
Beginner
Re: Output drop
@salemmahara
Happy to hear that you have applied the solution.
Please don't forget
Beginner
Re: Output drop
Hello @TAYYAB MUNIR
Unfortunately there is still OUTPUT DROP after increasing Softmax-buffer
SHAME ON CISCO !!!!!!!
Don't buy 3850 and 2960X ! Buggy platforms !!!!!!!!!!!!!!!
Beginner
Re: Output drop
 Hi @salemmahara
There is a solution to every problem, don't depress yourself.
Let's Make an Action Plan:
1) increase the softmax-Buffer to maximum 1200 and clear the counter, Check after 24 hours.
2) If you still observing the drops only solution to upgrade the IOS.
No worries I will support you until you get rid of this issue.
@Leo Laohoo@Georg Pauwen@Georg Pauwen@ I'm new to this community, I have no idea How we can engage Cisco official or TAC team to help this gentleman.
BR
Tayyab
Everyone's tags (4)
Hall of Fame Community Legend
Re: Output drop
The OP needs to contact Cisco TAC (and not you).
Beginner
Re: Output drop
Look like he doesn't have valid support contract otherwise, he will not wait for our feedback.
Beginner
Re: Output drop
Hi @salemmahara
Have you got chanced to work on this case? please share the updates.
BR
Tayyab
Beginner
Re: Output drop
Hi @TAYYAB MUNIR
How is it going?
I'm so sorry for a week of absence.
Actually, I'm a little confused and have no idea to solve the problem. Now, I'm going to manually set the speed of uplinks of my 2960s to 1G and check the result. My assumption is that they can be a part of this dark puzzle! Although there're working in 1G but they're intrinsically SFP+ !
There is another problem with upgrading to new version of IOS XE ! Cisco is releasing plenty of versions and it's a nightmare to go for one of those. Denali , Everest , 16.X , 3.X .... ! Which one should I go for !? Of course Denali looks good but Cisco is terrible in documentation. People have to search the internet and share their knowledge which sometimes is not trust-able.
Re: Output drop
@salemmahara wrote:
We're using 3.6.8 so it should be solved in this release
Raise a TAC Case.  Details in Bug IDs are seldom accurate and rarely updated.
Beginner
Re: Output drop
I had very similar issues recently. If you are using fiber you might want to check out the Tx/Rx values and heat levels on your transceivers with a:
sh transceiver detail command on the interface.
In my case, when the transceiver got hot, I would start dropping packets, and I had some erratic light issues as well.
Content for Community-Ad
July's Community Spotlight Awards
