08-06-2018 12:18 AM - edited 03-08-2019 03:50 PM
Hi All,
We are using Cisco 3750 switch where we have configured one port as SPAN port . The port is generating lot of output drops even we have QOS disabled glogablly, other ports are fine. We can see the traffic on the tool connected in the SPAN port. Since we did not configure QOS, i did not think of increasing buffer, what could be other cause of the output drops, could you share some idea how to fix it?
08-06-2018 12:29 AM
post the output of 'show interfaces x' where X is the interface that experiences the drops...
08-06-2018 01:00 AM
Please check the below output,
GigabitEthernet1/0/14 is up, line protocol is down (monitoring)
Hardware is Gigabit Ethernet, address is 2834.a220.678e (bia 2834.a220.678e)
Description: SPAN
MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
reliability 255/255, txload 4/255, rxload 1/255
Keepalive set (10 sec)
Full-duplex, 1000Mb/s, media type is 10/100/1000BaseTX
input flow-control is off, output flow-control is unsupported
Last input never, output 02:39:29, output hang never
Last clearing of "show interface" counters 01:01:29
Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 281883
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute output rate 18208000 bits/sec, 3030 packets/sec
0 packets input, 0 bytes, 0 no buffer
Received 0 broadcasts (0 multicasts)
0 watchdog, 0 multicast, 0 pause input
10674960 packets output, 7867741738 bytes, 0 underruns
0 unknown protocol drops
0 lost carrier, 0 no carrier, 0 pause output
08-06-2018 01:11 AM
turn flowcontrol on on the interface (flowcontrol receive on) and check if that makes a difference...
08-06-2018 01:52 AM
I just tried it but still an output drops increasing,
Description: SPAN
reliability 255/255, txload 3/255, rxload 1/255
input flow-control is on, output flow-control is unsupported
Last input never, output 00:05:18, output hang never
Last clearing of "show interface" counters 00:04:54
Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 8374
5 minute output rate 13103000 bits/sec, 2360 packets/sec
08-06-2018 02:01 AM
08-06-2018 02:09 AM
We have configured this interface as SPAN port, so this SPAN port connected to Gigamon TAP device which will send mirrored traffic to Netscout for packet analysis. When i look at Netscout we see the vlans sent from SPAN session created in 3750 switch and see the packet aswell.
Moreover there is no much configuration on Gigamon which will receive network traffic from SPAN port and send it to Netcout connect tool port. So i am not able to identify what could be an issue
08-06-2018 07:40 AM
