Packet sniffer/SSDP question....
jimmysands73_2
Level 5
Level 5
Trying to troubleshoot a network here.....
Question, why would a PC spit out a SSDP packet every .000015 seconds?  Is this normal?
2 Accepted Solutions
John Blakley
You should start disabling running apps and services to see if you can narrow down what app is causing that much traffic. SSDP is used for UPnP....if you don't need this service, you can disable UPnP and should see these go down.
HTH, John *** Please rate all useful posts ***
hobbe
Level 7
Level 7
Windows messenger is a strong candidate.
and well it sounds like a lot.
good luck
hth
John Blakley
hobbe
Level 7
Level 7
good luck
hth
Left yesterday with network normalized, get call today about 11:30 its gone to hell again (no connectivity past LAN rtr).  Sniff showed same data as screen shot.   The offending MAC was hard to track down, as shown below (Extreme), finally found it.
* 045-SW:41 # sh fdb 44:37:e6:5b:d8:8b
Index Mac Vlan Age Use Flags                                                             Port List
0cac0-013 44:37:E6:5B:D8:8B User_VLAN(0010) 0000000 0000 d m 20(Port)
Flags: (B) Egress Blackhole, (b) Ingress Blackhole, (d) Dynamic, (s) Static
(p) Permanent, (m) MAC, (S) secure MAC, (l) lockdown MAC
(L) lockdown MAC with timeout, (M) Mirror, IP
(z) translation MAC, (Q) Questionable, (R) Remapped
Total: 282 Static: 158 Perm: 0 Locked: 0 Secure: 0 Dynamic: 124 Dropped: 0
Questionable: 0 Remapped: 0 Locked with timeout: 0
FDB Aging time: 300 seconds
* 045-SW:42 # dis port 20
* 045-SW:43 # sh fdb 44:37:e6:5b:d8:8b
0cac0-019 44:37:E6:5B:D8:8B User_VLAN(0010) 0000000 0000 d m 26(Port)
Total: 280 Static: 158 Perm: 0 Locked: 0 Secure: 0 Dynamic: 122 Dropped: 0
* 045-SW:44 # dis port 26
* 045-SW:45 # sh fdb 44:37:e6:5b:d8:8b
0cac0-020 44:37:E6:5B:D8:8B User_VLAN(0010) 0000000 0000 d m 33(Port)
Total: 279 Static: 158 Perm: 0 Locked: 0 Secure: 0 Dynamic: 121 Dropped: 0
* 045-SW:49 # dis port 33
* 045-SW:50 #
* 045-SW:50 #
* 045-SW:50 # sh fdb 44:37:e6:5b:d8:8b
0cac0-006 44:37:E6:5B:D8:8B User_VLAN(0010) 0000000 0000 d m 7(Port)
Total: 276 Static: 158 Perm: 0 Locked: 0 Secure: 0 Dynamic: 118 Dropped: 0
* 045-SW:51 # dis port 7
* 045-SW:52 # sh fdb 44:37:e6:5b:d8:8b
0cac0-001 44:37:E6:5B:D8:8B User_VLAN(0010) 0000000 0000 d m 2(Port)
Total: 275 Static: 158 Perm: 0 Locked: 0 Secure: 0 Dynamic: 117 Dropped: 0
