Packet Tracer help
steeleb
I am tying to find information about a new filter that was add into packet tracer 7.2.1. In the options/preference menu there is a tap labeled "Answer Tree" which when selected provides an extensive list of options that can be selected, however I can not seem to figure out what effect selecting any of them has. When I tried to search for more information about this tap I found that there is no explanation to this feature nor is anyone really talking about it in forums. Can someone please provide a little more detail about this feature.
luis_cordova
Hi @steeleb ,
You can find the answer in the same program.
Follow these steps:
Click on the question sign
Your browser will open.
Now you must look in Preferences and go down to Answer Tree.
Remember to mark the correct answers as solved, since that helps other users with similar doubts
what you select in the Answer Tree is reflected in the Activity Wizard --> Answer Network...is that what you are looking for ?
