Packet Tracer Help
Ali Dena
Does anyone know is it possible to use a server to connect two switches?
Can I use Server to connect two networks or is it not possible. Kindly help me it is I can't get my head around it
Hello Ali,
You want to have the PCs from one end to have reachability to PCs on the other end? And that data going through the server? I'm not sure if such is possible, if the server is capable of forward traffic in such manners.
Maybe what you are looking for, is to have a switch instead of the server? Or a router, if the PCs belong to different broadcast domains.
Thank you.
Marin Grabovschi
just like in the real world, the only way I can see how this would work is by adding a second NIC to the server, as in the attached sample file...
I actually wanted to ask if the PCs from switch0 can ping the PCs from Switch1 because I've implemented it and I am getting request timed out
Hello Ali,
Thank you.
Marin Grabovschi
Yeah This is what I was trying to clarify thanks for helping
