[Packet Tracer] How to fix "Server Reset Connection"
I have an HQ router connected to a ISP router with an http server. The HQ router has a nat to translate all inside networks to 1 public IP:
  • HQ(config)#ip nat pool Public_Address 199.199.199.1 199.199.199.1 netmask 255.255.255.252
  • HQ(config)#ip nat inside source list 1 pool Public_Address overload
I also have 2 ACLs on the serial link of the HQ side for the HQ and the ISP:
  • access-list 100 permit tcp any any established (IN)
  • access-list 101 permit tcp any 201.10.10.0 0.0.0.255 eq www (OUT)
When I try to access the http server with a web browser sometimes it will succeed sometimes I will get a "server reset connection"
This link should be useful to fix the Server connection:
https://learningnetwork.cisco.com/thread/84469
Hope it is useful
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
Before you submit something, check the validity of your info.
THE LINK IS NO LONGER AVAILABLE.
THANK YOU.
