10-28-2017 04:13 AM - edited 03-08-2019 12:32 PM
Can anyone put me out of my misery here, I bet it's simple......
My switch in packet tracer lets me put anything as a host name as per the output below, it seems to ignore these rules:
The name must also follow the rules for ARPANET hostnames. They must start with a letter, end with a letter or digit, and have as interior characters only letters, digits, and hyphens. Names must be 63 characters or fewer.
Is this a limitation of Packet Tracer as I suspect?
#*$*#424234#copy run start
Destination filename [startup-config]? startup-config
Building configuration...
[OK]
#*$*#424234#show version
IOS (tm) C2950 Software (C2950-I6Q4L2-M), Version 12.1(22)EA4, RELEASE SOFTWARE(fc1)
Copyright (c) 1986-2005 by cisco Systems, Inc.
Compiled Wed 18-May-05 22:31 by jharirba
Image text-base: 0x80010000, data-base: 0x80562000
ROM: Bootstrap program is is C2950 boot loader
Switch uptime is 1 hours, 9 minutes, 42 seconds
Cisco WS-C2950-24 (RC32300) processor (revision C0) with 21039K bytes of memory.
Processor board ID FHK0610Z0WC
Last reset from system-reset
Running Standard Image
24 FastEthernet/IEEE 802.3 interface(s)
63488K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 0030.F2C1.B0C3
Motherboard assembly number: 73-5781-09
Power supply part number: 34-0965-01
Motherboard serial number: FOC061004SZ
Power supply serial number: DAB0609127D
Thanks in advance!
Solved! Go to Solution.
10-28-2017 05:53 AM - edited 10-28-2017 06:14 AM
Packet Tracer is a great simulator, but it has some limitations. I tested on a real router and I got the following message:
R1(config)#HO #*$*#424234
% Hostname contains one or more illegal characters.
% Hostname "#*$*#424234" is not a legal LAT node name, Using "CISCO_XXXXX"
#*$*#424234(config)#
*Oct 28 14:00:55.131: %CNS-3-WARNING: CNS ID not changed: bad hostname -Process= "Exec", ipl= 0, pid= 21
And it changed my hostname. I think it will change anyway but It is a notification about it is not a best practice and usually the netadmins set up hostnames related to any location.
11-05-2017 04:38 AM
Thanks for your help!
Much obliged.
Mihailo
11-05-2017 05:07 AM
It was a pleasure, have a great day
