Packets drops in switch 2960x for AXIS cameras
mdigiaco
Good afternoon colleagues,
I really need your help in this matter.
We have PTZ cameras brand AXIS. this cameras we use to monitor 24/7 a college. The company that monitor the cameras says that they are having drops of packets. The images have about 5 seconds delay.
#sh controllers cpu-interface
ASIC Rxbiterr Rxunder Fwdctfix Txbuflos Rxbufloc Rxbufdrain
ASIC0 0 0 0 0 0 0
ASIC1 0 0 0 0 0 0
HOL Fix Counts
No Fixes: 0 Added: 0 In Use: 0 Both: 0
CPU Heartbeat Statistics
Tx Success Tx Fail 1st Thr 2nd Thr Unthr RetryCtMax
39771955 0 0 0 0 1
Rx Delay
0 1 2 3 4
39771955 0 0 0 0
AddlDelay AdvanceCnt
0 0
Rx Retries by RetryCount
0 1 2 3 4 5 6
39771955 0 0 0 0 0 0
7 8 9
0 0 0
AddlRetry
cpu-queue-frames retrieved dropped invalid hol-block stray
rpc 224132378 0 0 0 0
stp 4607476 0 0 0 0
ipc 2293026 0 0 0 0
routing protocol 16888338 0 0 0 0
L2 protocol 2771003 0 0 0 0
remote console 0 0 0 0 0
sw forwarding 1841131 0 0 0 0
host 2435084 0 0 0 0
broadcast 7714749 0 0 0 0
cbt-to-spt 0 0 0 0 0
igmp snooping 13417414 0 0 0 0
icmp 0 0 0 0 0
logging 0 0 0 0 0
rpf-fail 0 0 0 0 0
dstats 64032366 0 0 0 0
cpu heartbeat 39771955 0 0 0 0
-------Supervisor ASIC exception status-------
Receive overrun 00000000 Transmit overrun 00000000
FrameSignatureErr 00000000
BadFrameErr 00000000 LenExceededErr 00000000
BadJumboSegments 00000000
-------PCIe Supervisor Rx Registers-------
DescriptorTableOffset 1D2C0000
q_num start end count current pop q_size stats disable
0 0x8000 0x81F3 0x0000 0x817A 0x0001 0x01F4 0x0000 0
1 0x81F4 0x8273 0x0000 0x8268 0x0001 0x0080 0xEAEB 0
2 0x8274 0x82F3 0x0000 0x8296 0x0001 0x0080 0x0000 0
3 0x82F4 0x8373 0x0000 0x8306 0x0001 0x0080 0x0000 0
4 0x8374 0x83F3 0x0000 0x83AF 0x0001 0x0080 0x0000 0
5 0x83F4 0x8433 0x0000 0x83F4 0x0000 0x0040 0x0000 0
6 0x8434 0x84B3 0x0000 0x849F 0x0001 0x0080 0x0000 0
7 0x84B4 0x8533 0x0000 0x84C0 0x0001 0x0080 0x0000 0
8 0x8534 0x8573 0x0000 0x8571 0x0001 0x0040 0x0000 0
9 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 1
10 0x8584 0x85C3 0x0000 0x858A 0x0001 0x0040 0x0000 0
11 0x85C4 0x85D3 0x0000 0x85C4 0x0000 0x0010 0x0000 0
12 0x85D4 0x8633 0x0000 0x85D4 0x0008 0x0060 0x0000 0
13 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 1
14 0x8644 0x8673 0x0001 0x8663 0x0001 0x0030 0x0000 0
15 0x8674 0x8677 0x0000 0x8677 0x0001 0x0004 0x0000 0
-------PCIe Supervisor Rx SW Pointers-------
q_num start end sw_read sw_cnt unfill(#|ptr|max) to_pop offset exception
0 0x8000 0x81F3 0x817A 0 0|0x0000|0 0 0 28
1 0x81F4 0x8273 0x8268 0 0|0x0000|0 0 0 9
2 0x8274 0x82F3 0x8296 0 0|0x0000|0 0 0 0
3 0x82F4 0x8373 0x8306 0 0|0x0000|0 0 0 15
4 0x8374 0x83F3 0x83AF 0 0|0x0000|0 0 0 3
5 0x83F4 0x8433 0x83F4 0 0|0x0000|0 0 0 0
6 0x8434 0x84B3 0x849F 0 0|0x0000|128 0 0 0
7 0x84B4 0x8533 0x84C0 0 0|0x0000|0 0 0 5
8 0x8534 0x8573 0x8571 0 0|0x0000|0 0 0 7
9 0x0000 0x0000 0x0000 0 0|0x0000|0 0 0 0
10 0x8584 0x85C3 0x858A 0 0|0x0000|0 0 0 51
11 0x85C4 0x85D3 0x85C4 0 0|0x0000|0 0 0 0
12 0x85D4 0x8633 0x85D4 0 0|0x0000|0 0 0 0
13 0x0000 0x0000 0x0000 0 0|0x0000|0 0 0 0
14 0x8644 0x8673 0x8663 1 0|0x0000|0 0 0 0
15 0x8674 0x8677 0x8677 0 0|0x0000|1 0 0 0
------PCIe Supervisor Rx SW Info-------------
q_num offset pop|max idle|max
0 0 1|23 0|10
1 0 1|5 0|2
2 0 1|4 0|10
3 0 1|10 0|10
4 0 1|1 0|3
5 0 0|0 0|0
6 0 1|37 0|5
7 0 1|1 0|6
8 0 1|4 0|10
9 0 0|0 0|0
10 0 1|2 0|10
11 0 0|0 0|0
12 0 1|1 0|0
13 0 0|0 0|0
14 0 1|15 0|10
15 0 1|1 0|0
-------PCIe Supervisor Tx Registers-------
DescriptorTableOffset 1D280000
q_num start end count current pushcnt pushptr qselect weight disable
0 0xBE00 0xBEFF 0x0000 0xBEBB 0x0001 0xBEBA 0x0000 30 0
1 0xBF00 0xBF7F 0x0000 0xBF61 0x0001 0xBF60 0x0001 10 0
2 0xBF80 0xBFBF 0x0000 0xBF80 0x0000 0x0000 0x0000 30 0
3 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0 1
4 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0 1
5 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0 1
6 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0 1
7 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0 1
-------PCIe Supervisor Tx SW Pointers-------
q_num start end sw_write txdone tx_cnt txdone_cnt
0 0xBE00 0xBEFF 0xBEBB 0xBEBB 318782651 318782651
1 0xBF00 0xBF7F 0xBF61 0xBF61 6835041 6835041
2 0xBF80 0xBFBF 0xBF80 0xBF80 0 0
3 0x0000 0x0000 0x0000 0x0000 0 0
4 0x0000 0x0000 0x0000 0x0000 0 0
5 0x0000 0x0000 0x0000 0x0000 0 0
6 0x0000 0x0000 0x0000 0x0000 0 0
7 0x0000 0x0000 0x0000 0x0000 0 0
------ASIC Rx/Tx Interrupts------
globalStatus=38602000 indicMask=FFFFFFFF intrMask=30F01010
asicRxTimeout asicTxTimeout asicRxDone asicTxDone asicTxOutofBuf
0 0 0 0 0
Configuration Dump : port-0 bus-1 dev-0 fn-0
(LE Size=256 bytes)
0x0 : 55551556 00100006 04000000 00000000
0x10 : 00000000 00000000 00000000 00000000
0x20 : 00000000 00000000 00000000 55551556
0x30 : 00000000 00000050 00000000 00000000
0x40 : 00000000 01816160 00000000 00000000
0x50 : 00047805 00000000 00000000 00000000
0x60 : 00000000 00000000 00007811 00000000
0x70 : 00000001 00000000 00038001 00000000
0x80 : 00110010 0000821B 00002810 0100D411
0x90 : 10110000 00000000 000003C0 00000000
0xA0 : 00000000 00000000 00000000 00000000
0xB0 : 00000000 00000000 00000000 00000000
0xC0 : 00000000 00000000 00000000 00000000
0xD0 : 00000000 00000000 00000000 00000000
0xE0 : 00000000 00000000 00000000 00000000
0xF0 : 00000000 00000000 00000000 00000000
Port-asic Port Enqueue Statistics - Summary
Port 0 TxQueue Enqueue Stats: 3320007904
Port 1 TxQueue Enqueue Stats: 22145475
Port 2 TxQueue Enqueue Stats: 22230929
Port 3 TxQueue Enqueue Stats: 22164264
Port 4 TxQueue Enqueue Stats: 2
Port 5 TxQueue Enqueue Stats: 22436552
Port 6 TxQueue Enqueue Stats: 22184053
Port 7 TxQueue Enqueue Stats: 22166214
Port 8 TxQueue Enqueue Stats: 22230691
Port 9 TxQueue Enqueue Stats: 22156644
Port 10 TxQueue Enqueue Stats: 22182335
Port 11 TxQueue Enqueue Stats: 22193057
Port 12 TxQueue Enqueue Stats: 22230415
Port 13 TxQueue Enqueue Stats: 0
Port 14 TxQueue Enqueue Stats: 879091181
Port 15 TxQueue Enqueue Stats: 5351009
Port 16 TxQueue Enqueue Stats: 2
Port 17 TxQueue Enqueue Stats: 18422261
Port 18 TxQueue Enqueue Stats: 2
Port 19 TxQueue Enqueue Stats: 18430960
Port 20 TxQueue Enqueue Stats: 2
Port 21 TxQueue Enqueue Stats: 18423740
Port 22 TxQueue Enqueue Stats: 12204249
Port 23 TxQueue Enqueue Stats: 18055922
Port 24 TxQueue Enqueue Stats: 18068584
Port 25 TxQueue Enqueue Stats: 26
Port 26 TxQueue Enqueue Stats: 4984542
Port 27 TxQueue Enqueue Stats: 0
Port-asic Port Enqueue Statistics - Details
Configuration of the uplink in the switch:
switchport trunk native vlan 999
switchport mode trunk
switchport nonegotiate
ip arp inspection trust
load-interval 30
srr-queue bandwidth share 1 30 35 5
priority-queue out
mls qos trust dscp
macro description EgressQoS
storm-control broadcast level 33.00
storm-control multicast level 33.00
ip dhcp snooping trust
end
Please any suggestion in order to prevent those loss?
Reza Sharifi
Can you post the config for the port where the camera is connected?
switchport access vlan 3966
switchport mode access
no logging event link-status
priority-queue out
no snmp trap link-status
spanning-tree portfast edge
spanning-tree bpdufilter enable
end
Do they still see packet drops if you remove "priority-queue out" command?
Yes they do
