Hi!
Cisco docs say that:
"You can use input port ACLs, router ACLs, and VLAN maps on the same switch. However, a port ACL takes precedence over a router ACL or VLAN map:
- When both an input port ACL and a VLAN map are applied, incoming packets received on ports with a port ACL applied are filtered by the port ACL. Other packets are filtered by the VLAN map."
However, testing reveals that PACLs and VACLs can work together on the SAME L2 interface:
interface FastEthernet0/3
switchport access vlan 16
switchport mode access
ip access-group 104 in
S3650#sh access-l 104
Extended IP access list 104
10 deny icmp 172.16.16.0 0.0.0.255 host 172.16.11.100 echo
20 permit icmp 172.16.16.0 0.0.0.255 host 172.16.1.100 echo
30 permit ip any any
S3650#sh vlan filter
VLAN Map test is filtering VLANs:
16
S3650#sh vlan access-map
Vlan access-map "test" 10
Match clauses:
ip address: 100
Action:
drop
Vlan access-map "test" 20
Match clauses:
ip address: 102
Action:
forward
S3650#sh access-l 100
Extended IP access list 100
10 permit icmp 172.16.16.0 0.0.0.255 host 172.16.1.100 echo
S3650#sh access-l 102
Extended IP access list 102
10 permit ip any any
STEND#4
[Resuming connection 4 to 1.1.1.1 ... ]
Server3#ping 172.16.11.100
Sending 5, 100-byte ICMP Echos to 172.16.11.100, timeout is 2 seconds:
Success rate is 0 percent (0/5)
Server3#ping 172.16.1.100
Sending 5, 100-byte ICMP Echos to 172.16.1.100, timeout is 2 seconds:
Server3#ping 172.16.12.100
Sending 5, 100-byte ICMP Echos to 172.16.12.100, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/2/4 ms
So, it seems that PACL is checked first, then VACL. This is a pure L2 3560 switch, 12.2(25)SEE2.
Am I missing something here?
Thx.
