PAgP port in stand-alone mode
simionov.adrian
Devices are 3750-24TS Switches, software version is 12.2(55)SE6.
I need some more advices about how to troubleshoot this issue, I have a pair of ports which are not bundling, no matter what. Is the same behavior with LACP or PAgP. In this outputs I have only the PAgP case.
Output is similar to:
Group  Port-channel  Protocol    Ports
12     Po12(SD)        PAgP      Fa1/0/23(I) Fa1/0/24(I)
Configuration on ports is simple:
SW1:
interface FastEthernet1/0/24
switchport mode trunk
channel-group 12 mode desirable
end
interface FastEthernet1/0/23
end
SW2:
end
end
Cables are connected:
SW1#sh cdp neighbors | i SW2
SW2              Fas 1/0/24        168              S I   WS-C3750- Fas 1/0/24
SW2              Fas 1/0/23        167              S I   WS-C3750- Fas 1/0/23
SW1#
SW2#sh cdp neighbors | i SW1
SW1              Fas 1/0/24        131              S I   WS-C3750- Fas 1/0/24
SW1              Fas 1/0/23        131              S I   WS-C3750- Fas 1/0/23
SW2#
IOS is stating that port negociation is working ok.
SW1#sh int fa 1/0/23 | i media
  Full-duplex, 100Mb/s, media type is 10/100BaseTX
SW1#sh int fa 1/0/24 | i media
SW1#
SW2#sh int fa1/0/23 | i media
SW2#sh int fa1/0/24 | i media
SW2#
Some troubleshooting steps:
I rebooted the switches and changed the cables.
I made advanced diagnostics for hardware faults of the devices, diag passed.
I noticed that on SW 2 there are no received counters, but I did not make a sniff yet to know if are not sent, or not understood by the other side.
SW1#sh pagp counter
          Information         Flush        PAgP
Port      Sent    Recv     Sent    Recv    Err Pkts
Channel group: 12
Fa1/0/23  2162    158      0       0       0
Fa1/0/24  2163    159      0       0       0
SW2#sh pagp counters
Channel group: 12
Fa1/0/23  167     0        0       0       0
Fa1/0/24  169     0        0       0       0
I made debug and I get the following log. Last 4 logs will repeat forever.
*Mar  1 11:31:01.985: FEC: pagp_switch_stay_shutdown: port Fa1/0/23 agport Po12
*Mar  1 11:31:01.985: FEC: pagp_switch_stay_shutdown: port Fa1/0/24 agport Po12
*Mar  1 11:31:01.994: FEC: pagp_switch_hwif_comingup: port Po12
*Mar  1 11:31:01.994: FEC: pagp_switch_reset_cannot_bundle_ports: group 12
*Mar  1 11:31:03.990: %LINK-3-UPDOWN: Interface FastEthernet1/0/23, changed state to up
*Mar  1 11:31:03.990: %LINK-3-UPDOWN: Interface FastEthernet1/0/24, changed state to up
*Mar  1 11:31:06.523: FEC: pagp_switch_port_up: Fa1/0/23
*Mar  1 11:31:06.523: FEC: pagp_switch_invoke_port_up: Fa1/0/23
*Mar  1 11:31:06.523: FEC: pagp_switch_agc_compatable: comparing GC values of Fa1/0/23 Po12 flag = 1 1
*Mar  1 11:31:06.523: FEC: pagp_switch_port_attrib_diff: Fa1/0/23 Po12 same
*Mar  1 11:31:06.523: FEC: pagp_switch_agc_compatable: GC values are compatable
*Mar  1 11:31:06.523: FEC: pagp_switch_find_master: group 12
*Mar  1 11:31:06.523: FEC: pagp_switch_calculate_vgc: gc for port Fa1/0/23 is C0001
*Mar  1 11:31:06.523: FEC: pagp_switch_port_up: Fa1/0/24
*Mar  1 11:31:06.523: FEC: pagp_switch_invoke_port_up: Fa1/0/24
*Mar  1 11:31:06.523: FEC: pagp_switch_agc_compatable: comparing GC values of Fa1/0/24 Po12 flag = 1 1
*Mar  1 11:31:06.523: FEC: pagp_switch_port_attrib_diff: Fa1/0/24 Po12 same
*Mar  1 11:31:06.523: FEC: pagp_switch_agc_compatable: comparing GC values of Fa1/0/24 Fa1/0/23 flag = 1 1
*Mar  1 11:31:06.523: FEC: pagp_switch_port_attrib_diff: compare PAgP modes for Fa1/0/24
*Mar  1 11:31:06.523: FEC: pagp_switch_port_attrib_diff: Fa1/0/24 Fa1/0/23 same
*Mar  1 11:31:06.532: FEC: pagp_switch_agc_compatable: comparing GC values of Fa1/0/24 Fa1/0/23 flag = 1 1
*Mar  1 11:31:06.532: FEC: pagp_switch_port_attrib_diff: compare PAgP modes for Fa1/0/24
*Mar  1 11:31:06.532: FEC: pagp_switch_port_attrib_diff: Fa1/0/24 Fa1/0/23 same
*Mar  1 11:31:06.532: FEC: pagp_switch_agc_compatable: GC values are compatable
*Mar  1 11:31:06.532: FEC: pagp_switch_calculate_vgc: gc for port Fa1/0/24 is C0001
*Mar  1 11:31:31.765: FEC: fec_dontbundle: Fa1/0/23
*Mar  1 11:31:31.765: FEC: pagp_switch_independent_port: Fa1/0/23
*Mar  1 11:31:31.798: FEC: pagp_switch_reset_load_index: reading load-index for port Fa1/0/23
*Mar  1 11:31:31.933: FEC: fec_dontbundle: Fa1/0/24
*Mar  1 11:31:31.933: FEC: pagp_switch_independent_port: Fa1/0/24
*Mar  1 11:31:31.966: FEC: pagp_switch_reset_load_index: reading load-index for port Fa1/0/24
*Mar  1 11:31:32.889: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet1/0/23, changed state to up
*Mar  1 11:31:33.099: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet1/0/24, changed state to up
*Mar  1 11:31:40.086: FEC: fec_unbundle: Fa1/0/23
*Mar  1 11:31:40.086: FEC: pagp_switch_change_vgc: gcchngreq == 0 for Fa1/0/23
*Mar  1 11:31:40.086: FEC: pagp_switch_change_vgc: Fa1/0/23 gcchngreq = 0 gc = C0001
*Mar  1 11:31:40.086: FEC: pagp_switch_unindependent_port: Fa1/0/23
*Mar  1 11:31:42.267: FEC: fec_unbundle: Fa1/0/24
*Mar  1 11:31:42.267: FEC: pagp_switch_change_vgc: gcchngreq == 0 for Fa1/0/24
*Mar  1 11:31:42.267: FEC: pagp_switch_change_vgc: Fa1/0/24 gcchngreq = 0 gc = C0001
*Mar  1 11:31:42.267: FEC: pagp_switch_unindependent_port: Fa1/0/24
*Mar  1 11:31:57.132: FEC: fec_dontbundle: Fa1/0/23
*Mar  1 11:31:57.132: FEC: pagp_switch_independent_port: Fa1/0/23
*Mar  1 11:31:57.132: FEC: pagp_switch_reset_load_index: reading load-index for port Fa1/0/23
*Mar  1 11:31:59.237: FEC: fec_dontbundle: Fa1/0/24
*Mar  1 11:31:59.237: FEC: pagp_switch_independent_port: Fa1/0/24
*Mar  1 11:31:59.237: FEC: pagp_switch_reset_load_index: reading load-index for port Fa1/0/24
*Mar  1 11:32:06.401: FEC: fec_unbundle: Fa1/0/23
*Mar  1 11:32:06.401: FEC: pagp_switch_change_vgc: gcchngreq == 0 for Fa1/0/23
*Mar  1 11:32:06.401: FEC: pagp_switch_change_vgc: Fa1/0/23 gcchngreq = 0 gc = C0001
*Mar  1 11:32:06.401: FEC: pagp_switch_unindependent_port: Fa1/0/23
*Mar  1 11:32:11.980: FEC: fec_unbundle: Fa1/0/24
*Mar  1 11:32:11.980: FEC: pagp_switch_change_vgc: gcchngreq == 0 for Fa1/0/24
*Mar  1 11:32:11.980: FEC: pagp_switch_change_vgc: Fa1/0/24 gcchngreq = 0 gc = C0001
*Mar  1 11:32:11.980: FEC: pagp_switch_unindependent_port: Fa1/0/24
*Mar  1 11:32:23.749: FEC: fec_dontbundle: Fa1/0/23
*Mar  1 11:32:23.749: FEC: pagp_switch_independent_port: Fa1/0/23
*Mar  1 11:32:23.749: FEC: pagp_switch_reset_load_index: reading load-index for port Fa1/0/23
*Mar  1 11:32:29.193: FEC: fec_dontbundle: Fa1/0/24
*Mar  1 11:32:29.193: FEC: pagp_switch_independent_port: Fa1/0/24
*Mar  1 11:32:29.193: FEC: pagp_switch_reset_load_index: reading load-index for port Fa1/0/24
*Mar  1 11:32:33.337: FEC: fec_unbundle: Fa1/0/23
*Mar  1 11:32:33.337: FEC: pagp_switch_change_vgc: gcchngreq == 0 for Fa1/0/23
*Mar  1 11:32:33.337: FEC: pagp_switch_change_vgc: Fa1/0/23 gcchngreq = 0 gc = C0001
*Mar  1 11:32:33.337: FEC: pagp_switch_unindependent_port: Fa1/0/23
*Mar  1 11:32:40.837: FEC: fec_unbundle: Fa1/0/24
*Mar  1 11:32:40.837: FEC: pagp_switch_change_vgc: gcchngreq == 0 for Fa1/0/24
*Mar  1 11:32:40.837: FEC: pagp_switch_change_vgc: Fa1/0/24 gcchngreq = 0 gc = C0001
*Mar  1 11:32:40.837: FEC: pagp_switch_unindependent_port: Fa1/0/24
Hello
wondering as these are 3750s are the ports you are trying to connect just are the provisioned ports and not actually the correct physical ports
without ehterchannel can you trunk between the two swiches? - if so
for pagp try port-channel mode non silent
res
Paul
Sent from Cisco Technical Support Android App
Kind Regards
Paul
InayathUlla Sharieff
If I was you I could have tried the following thing:
Step 1 : Default the configuration on both the interface.
Step 2 : Re-configure the interface
Ex:
interface FastEthernet1/0/23  & interface FastEthernet1/0/24
no shut
switchport
no ip address
channel-group 12 mode desirable  -- If this doesnt work try with mode "on"
Step 3 : Under the port channel add the configuration for trunk.
ex:
int port-channel 12
no shut
no ip address.
Kindly do the same and provide us the result.
Outputs required for troubleshooting:
show etherchannel summary
show int trunk
show spanning-tree interface port-channel 12
show spanning-tree interface FastEthernet1/0/23 & 24
show log
Inayath
*Plz rate the usefull posts.
simionov.adrian
I finally solved this issue.
The problem was with a vlan filtering access list which was matching all mac addresses and was applied to all vlans.
After modifying the access-list to permit this new mac addresses everything was ok.
