password recovery for cisco 6506
ssamiullah
please let me knew the password recovery for 6506 core switch. Tried the standard method of using Break key,but still the switch is booting up the IOS and not going into Rommon mode...please find below details
00:03:19: %DIAG-SP-6-DIAG_OK: Module 1: Passed Online Diagnostics
00:03:20: %OIR-SP-6-INSCARD: Card inserted in slot 1, interfaces are now online
00:03:30: %PM_SCP-SP-3-TRANSCEIVER_UNSUPPORTED: Unsupported transceiver in LAN port 1/6
User Access Verification
Password:
System Bootstrap, Version 8.5(2)
Copyright (c) 1994-2007 by cisco Systems, Inc.
Cat6k-Sup720/SP processor with 1048576 Kbytes of main memory
Autoboot executing command: "boot bootdisk:"
Initializing ATA monitor library...
string is bootdisk:s72033-ipbase-mz.122-33.SXH4.bin
Loading image, please wait ...
Self extracting the image... [OK]
Self decompressing the image : ##########################################################################
################################################################################### [OK]
Press Break on the terminal keyboard right after the RP gains control of the console port. On the Catalyst 6000 that runs Cisco IOS Software, the SP boots first. After it has booted, it turns control over to the RP. After the RP gains control, initiate the break sequence. The RP gains control of the console port when you see this message. (Do not initiate the break sequence until you see this message):
00:00:03: %OIR-6-CONSOLE: Changing console ownership to route processor
More info at:
http://www.cisco.com/en/US/products/hw/switches/ps700/products_password_recovery09186a0080133fb1.shtml
