PAT/NAT Question
myates123
Is it possible to do PAT/NAT on two laptops that are connected via their own switch onto one router?
I would like to do private/public IPs on laptops connected to different switches.
Enlcosed is what I am trying to do.
Any help is greatly appreciated!
Francesco Molino
Not sure i understand what you want to achieve. Do you want to do nat to access internet simply or do you want to a static nat?
Anyways, your router interface facing the public side will be the nat outside and both interfaces facing lan will be in nat inside.
Then you'll need to configure the acl to allow internet access and so natting your private IPs to public IPs.(same as a standard nat configuration)
Francesco
PS: Please don't forget to rate and select as validated answer if this answered your question
Francesco Molino
Francesco
Thank you. How do you configure the acl to allow internet access?
you need to include the IP address (ranges) of both laptops in your ACL. If possible, post the (zipped) Packet Tracer project (.pkt) file. Otherwise, let's assume the below:
Laptop_1 has IP address 192.168.10.2/24
Laptop_2 has IP address 192.168.20.2/24
The router configuration, NAT, and corresponding access list would look like this:
Router
interface GigabitEthernet0/0
description Uplink to ISP
ip address 1.1.1.1 255.255.255.252
ip nat outside
interface GigabitEthernet0/1
description Link to Laptop_1
ip address 192.168.10.1 255.255.255.0
ip nat inside
interface GigabitEthernet0/2
description Link to Laptop_2
ip address 192.168.20.1 255.255.255.0
ip nat inside
ip nat inside source list 1 interface GigabitEthernet0/0 overload
access-list 1 permit 192.168.10.0 0.0.0.255
access-list 1 permit 192.168.20.0 0.0.0.255
