PBR clarification
gautamzone
Dear friends,
Just wanted a confirmation on the working of PBR
1. set ip default next-hop with multiple ip addresses
If the interface connected to the ip address (mentioned in the set ip default next-hop command) is down, will it automatically stop forwarding to the first ip address and route to the second.
Example:
set ip default next-hop 10.3.1.97 10.2.0.1
If 10.3.1.97 is connected to Tunnel0 interface and tunnel0 has gone down, will it stop forwarding to Tunnel 0 and just only forward to 10.2.0.1?
2. Will set ip default next-hop override default route in the routing table?
Note: Both the above clarifications are for 6500 running SXI2a code if that might matter.
Thanks and Regards
Gautam
Mohamed Sobair
Level 7
Level 7
1- Yes.
2- Yes, but this is conditional command, its executed Only IF matching route is exist on the routing table.
Mohamed
