Highlighted
Beginner
PBR lag when remoting a machine
HI guys,
I have setup a PBR on my catalyst 3750.
here is my diagram.
Continous ping went and works well with all vlans to other ISPs..
My problem is, when I do remoting a machine on a different VLAN. I experience a Lag (interval).
Scenario:
If im on VLAN 2 and im remoting my server machine (Windows R2) which is on VLAN 1 (10.0.0.3). there is a lag hapenning. it said connecting... then after a bit, connected.. then after a while.. connecting.. it goes on and on.
I can ping the server continously without a lag.
I tried to disabled the route-map on catalyst.. the connection run smooth.
did you experience it? I suspect I have a problem with my PBR
Anyway where is my config on my Catalyst 3750.
interface Vlan2
ip address 10.2.0.1 255.255.0.0
ip policy route-map routetoISP1
interface Vlan4
ip address 10.4.0.1 255.255.0.0
interface Vlan3
ip address 10.5.0.1 255.255.0.0
ip helper-address 10.0.0.4
ip policy route-map routetoISP2
interface Vlan5
ip route 0.0.0.0 0.0.0.0 10.0.0.1
access-list 10 permit 10.2.0.0 0.0.255.255
access-list 10 permit 10.4.0.0 0.0.255.255
access-list 20 permit 10.3.0.0 0.0.255.255
access-list 20 permit 10.5.0.0 0.0.255.255
route-map routetoISP1 permit 10
match ip address 10
set ip next-hop 10.0.0.1
route-map routetoISP2 permit 20
match ip address 20
set ip next-hop 10.0.0.2
Please advise whats going wrong.
0 REPLIES 0
Content for Community-Ad
