04-04-2016 09:04 AM - edited 03-08-2019 05:12 AM
IOS is (cat4500e-UNIVERSALK9-M) and license level is "License Level: ipbase"
Supervisors are WS-X45-SUP7-E
Should I be able to do policy-based routing with this setup or do I need to do an upgrade?
04-04-2016 11:01 AM
Hi!
PBR is supported in IP Base license level. Please refer to the following link for 4500 Realease Note and available features in detail:
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst4500/release/note/ol-38xe-4500e.html
Hope it helps, best regards!
JC
04-04-2016 11:41 AM
Just realized my IOS version is 3.04.00SG
Looks like I may need to get up to 3.8 to get PBR, is that right?
04-04-2016 01:54 PM
Hi!
Yes, 3.8 release is the recommended and most up to date, It will sure supports PBR feature.
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst4500/release/note/ol-38xe-4500x.html
JC
