PBR on Cat 4500 with Supervisor 6E
paulomv
Hi all,
I'm trying to configure PBR on a Catalyst 4500 with Supervisor 6E running version 12.2(46)SG Enterprise Services.
I'm not able to configure PBR on the interfaces using the command ip policy-map.
Did this feature disappear on this Supervisor???
I've already searched on the Feature Navigator and PBR is not on the list for either license types!
I'm replacing a Sup3 that has that feature configured.
Any help?
Paulo
I
5 Replies 5
paulomv
OK, just checked that PBR is not supported on Supervisor 6-E.
Is there any reason for this? Will it be supported in the future?
did you use same IOS 12.2.46.SG on SUP3 or not?
The Supervisor 3 is running 12.2(25)EWA8.
I believe that PBR would be working on Sup3 on version 12.2(46)SG. The limitation is really on Supervisor 6-E which does not support PBR.
may you pls try for me that whether PBR is working on SUP3 with 12.2(46)SG, because the feature navigator indicate that PBR is not supported for this IOS..thanks..
http://tools.cisco.com/ITDIT/CFN/jsp/index.jsp
Don't worry about that version for Supervior 3 because version 12.2(46)SG is for Sup6-E only.
The latest version for Sup3 is 12.2.25-EWA14 which certainly supports PBR (Must be Enhanced L3 license) because Sup3 supports that feature.
The limitation I've found is in the Hardware not in the Software.
