PBR & OSPF
01Scary01
hi
i have a problem in my network i can`t handle in myself
6 routers in network running ospf & 2 of them are asbr
i call them A & B
router A is a broadband BRAS with some static routes that has been adverised to ospf, some connected routes & a tunnel to a remote site
router B is asbr that runs bgp & ospf
there is 2 ip pool in router A that should go throught the remote site to access the internet & use ospf to access the local network. the rest of pools use ospf to access local network & use router B to access the internet
is any soloution to accoumplish above cenario?
if i use PBR match specific pool & set next hop (remote site) packets go trought the remote site & come back trought router B to access local network(local network has valid ips)
0 Replies 0
