Join Customer Connection to register!
642
danny4569
Beginner
PBR problem on 3750X
HI.
I have a stack of two 3750X, ver 12.2(55)SE3, IPSERVICES license.
SDM prefer configured for routing.
The following configuration is configured on the switch:
switch 1 provision ws-c3750x-48
switch 2 provision ws-c3750x-48
system mtu routing 1500
ip routing
ip multicast-routing distributed
interface GigabitEthernet1/0/38
switchport access vlan 21
switchport mode access
spanning-tree portfast
interface Vlan19
ip address 10.1.19.253 255.255.255.0
ip pim dense-mode
interface Vlan21
ip address 10.1.21.254 255.255.255.0
ip pim dense-mode
ip policy route-map DATALINKS
interface Vlan77
ip address 7.7.7.1 255.255.255.0
interface Vlan88
ip address 8.8.8.1 255.255.255.0
ip access-list extended HDRM
permit tcp any any eq 6000
permit udp any any eq 6000
ip access-list extended LDRM
permit udp any any eq 5000
permit tcp any any eq 5000
permit udp any any eq 1967
permit udp any any eq 20301
ip access-list extended SCOM
permit udp any any eq 9000
permit tcp any any eq 9000
route-map DATALINKS permit 10
match ip address SCOM
set ip next-hop 10.1.19.254
route-map DATALINKS permit 20
match ip address HDRM
set ip next-hop 8.8.8.2
route-map DATALINKS permit 30
match ip address LDRM
set ip next-hop 7.7.7.2
The problem is that when I am sending a file from LAN (Source is 10.1.21.1) to LAN only the first "route-map DATALINKS permit 10" is working fine.
The other two "route-map DATALINKS permit 20" and "route-map DATALINKS permit 30" allows to pass data which is only up to the MTU  size
(1472 Byte payload). Above MTU size I am losing data.
If I am changing the order of the entries in the route-map, the first is OK and the other lose data.
Any idea how to solve the problem?
Danny.
0 REPLIES 0
