PBR to Verify Next Hop on MSFC
d.fraser
I have 12.2(17a)SX4 on MSFC and want to insert a static route to an ip next hop based on a L2 interfcae being up...Any ideas.
7 Replies 7
npereira
HSRP with PBR
I don't think that will help..
I want to use a static route pointing to a firewall as a next hop. But I only want the static route to work if the firewall is alive. So I think I have to 'track' the firewall state using either CDP or ICMP, like http://www.cisco.com/en/US/partner/products/sw/iosswrel/ps5207/products_feature_guide09186a00801d1e95.html
but I am having trouble getting it going.
If I don't use this method then any ideas are welcome.
JORGE RODRIGUEZ
Level 10
Level 10
we'll work with subnet 10.169.100.0 as users segment and the firewall being 10.10.0.1 ,
10.10.0.2, and 10.10.0.3 will be alternate routes if 10.10.0.1 is down etc..
1- crteate your access list
access-list 1 permit 10.169.100.2 ( per host )
access-list 1 permit 10.169.100.1 ( per host )
access-list 1 permit 10.169.100.10 ( per host )
or
access0list 1 permit 10.168.100.0 ( per subnet )
create a route map
example:
route-map alternate-routes permit 10
match ip address 1
set ip next-hop 10.10.0.1
set ip next-hop 10.10.0.2
set ip next-hop 10.10.0.3
set ip next-hop verify-availability ( verify next hop is a cdp neighbor )
the PBR will try the next available hop , your next hop is 10.10.0.1 firewall and if that hop is down
it will try 10.10.0.2 as an alternate route and so on.
Apply the route map to the interface
interface vlan 169
ip policy route-map alternate-routes
HTH, rate if this helps
Jorge
Jorge Rodriguez
I understand your solution but I have a more complex problem.
The firewall is managed by another provider. I have asked if it will supply CDP or respond to ICMP, I have not heard but I will assume it will for now.
There are two loactions, a hot and a cold site. Each site has a firewall attached to my switch (MSFC). There are approx 10,000 people behind the swicths who want to talk through the host swicth/firewall if it is alive, or through the cold swicth/firewall if the hot one is dead.
Hence I want to inject the hot firewll into OSPF as a next hop only if it is alive.
I tried creating a static
ip route 10.10.0.1
Creating an ACL
access-list 10 per
Biulding the route map
route-map FIREWALL per 10
match ip add 10
set next hop 10.10.0.1
set next-hop ver-avail
But this seems to be mixing features, PBR on the vlan interfcae, and injecting into OSPF based on the same route-map.
I am starting to think that the best way to do it is make the interface between my swicth and the firewall a L3 interfcae, then I can use a static route pointing to the local swicth L3 interfcae. That way if the switch Ethernet is down, the static won't inject into ospf.
ip route Gig3/8
I don't know, perhaps would'nt that be possibly by implemeting two default routes at your core-MSFC?
that is :
say both sites are up, hot and cold.
ip route 0.0.0.0 0.0.0.0 10.10.0.1 (hot site)
ip route 0.0.0.0 0.0.0.0 10.10.0.2 (cold site)
perhaps place and admin distance for route preference .
under ospf
redistribute static
Jorge Rodriguez
David,
Jorge's recommendation with an additional feature, Reliable static route using object tracking, should help you achieve what you are trying to do.
With this feature you can track the firewall IP address and when the it becomes unreachable the router would remove the primary default route and start using the backup default route (floating static) to route the traffic.
Have a look at this link to configure this feature.
http://cisco.com/en/US/products/sw/iosswrel/ps5413/products_feature_guide09186a00801d862d.html
Sundar
My 12.2(17a) IOS may limit me here.
I think I have to use the MSFC interfcae as the next hop, with the caveats that is must be a L3, and I wear the ARP problem as specified. I can poit to multiple /26's behind the firewall, which will limit the ARP issue.
I can redistribute static will differnt costs etc...no brainer.
http://www.cisco.com/en/US/partner/tech/tk365/technologies_tech_note09186a00800ef7b2.shtml
