pc won't ping with rip routing
valeriantendy
hello i have a problem with the rip routing. i cannot ping any pc to another. i've tried setting the rip routing but i cannot find the problem
valeriantendy
Hi I have resolved the issue alone
6 Replies 6
@valeriantendy
Can I see your topology picture and the router config, If possible?
 I can not open the PKT file right now but mabe I can help you.
valeriantendy
here it is
is it better to use ospf for this network?
From where to where you can not ping exactly?  I opened you file now and it seems all good here. I could ping from PCs to PCs, PC to server.
Mancunian
Can PCs ping their default gateways?
Is RIP configured correctly (version 2, correct networks)?
Are RIP routes visible in show ip route rip?
Are interfaces up and IP addresses correct?
Is the default gateway correct on all PCs?
valeriantendy
