Per host bandwidth limiting
2044418Puts
I'm working on the following situation:
LAN (10.0.0.0/22) ---> Gig0/1 Router Gig0/0 ---> 50 mbps Internet connection.
I would like to configure a PER HOST bandwidth limitation of 1 mbps. How can this be achieved?
I was thinking about the following situation:
ACL TRAFFIC_GIG_0_1_IN
permit ip 10.0.0.0/20 any
ACL TRAFFIC_GIG_0_1_OUT
permit ip any 10.0.0.0/20
class-map TRAFFIC_GIG_0_1_IN_CM
match acl TRAFFIC_GIG_0_1_IN
class-map TRAFFIC_GIG_0_1_OUT_CM
match acl TRAFFIC_GIG_0_1_OUT
policy-map TRAFFIC_GIG_0_1_OUT_PM
police 1000000 conform-action transmit exceed-action drop
policy-map TRAFFIC_GIG_0_1_IN_PM
int giga 0/1
service-policy input TRAFFIC_GIG_0_1_IN_PM
service-policy output TRAFFIC_GIG_0_1_OUT_PM
Dont mind the exact syntax...
Will this work or will this just ratelimit the subnet as a whole?
Thanks!
mlouis
If you have a 4500/6500 you can use microflow policing. See that feature here.
4500
http://www.cisco.com/en/US/docs/switches/lan/catalyst4500/12.2/37sg/configuration/guides/qos.html#wp1371348
6500
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps708/prod_white_paper0900aecd803e5017.html
Otherwise, how many hosts do you have? You could rate limit per host but there is a limit on the number of policies and classes per device so it doesn't scale really well.
