Per VLAN Rate Limiting on Cisco 3850 Switch
claurie
Hi All,
I have a 3850 Switch with several Trunk Ports. Each of these Trunk Ports have several unique VLANs configured. I have a need to rate limit each VLAN individually and independent of the physical Trunk Interface.
e.g. Trunk Port ge0/0/1
       VLAN 1007 - to be Limited to 20 Mbps
       VLAN 1008 - to be Limited to 50 Mbps
       VLAN 1009 - to be Limited to 100 Mbps
Is this possible? If so, how is it achieved?
Thanks in advance for any and all assistance!
Hello
Just checked the cisco doc for 3850 vlan qos looks like it per-port-vlan  - here
Examples: Policer VLAN Configuration
The following example displays a VLAN policer configuration. At the end of this configuration, the VLAN policy map is applied to an interface for QoS.
conf t
class-map vlan100
match vlan 100
policy-map vlan100
policy-map class vlan100
police 100000 bc conform-action transmit exceed-action drop
interface gigabitEthernet1/0/5  <---physical interfaces not SVI
service-policy input vlan100
Kind Regards
Paul
Hello
The below config is based on 3650 vlan qos has i don't have access to 3850's so it may not be applicable as i am aware the 3750 had some cavets regards policing on svi's
conf t
mls qos
class-map Trunk_Interfaces
match input-interface ge0/0/1 ge0/0/x ge0/0/x etc..
policy-map vlan1007
class Trunk_Interfaces
police 20480000 640000 exceed-action drop
policy-map vlan1008
police 51200000 1600000 exceed-action drop
policy-map vlan1009
police 102400000 3200000 exceed-action drop
ip access-list extended 110
permit ip any any
class-map IP
match access-group 110
policy-map vlan1007_parent
class IP
service-policy vlan1007
policy-map vlan1008_parent
class IP
service-policy vlan1008
policy-map vlan1009_parent
class IP
service-policy vlan1009
interface Vlan1007
service-policy input vlan1007_parent
interface Vlan1008
service-policy input vlan1008_parent
interface Vlan1009
service-policy input vlan1009_parent
int ge0/0/x (all trunk links with vlan1007-9 traversing them)
mls qos vlan-based
Kind Regards
Paul
Hello
conf t
class-map vlan100
match vlan 100
policy-map vlan100
Kind Regards
Paul
Hi Paul,
Firstly, thanks for the effort you put into finding a solution for my requirements - greatly appreciated.
Whilst the solution config is exactly what I am looking for - I have hit a brick wall. Using CLI,
I have successfully completed config steps for the first vlan1001 however, when I go to apply the second vlan1007 service-policy to the interface, the switch advises service-policy vlan1001 is already assigned to the interface.
Is there a step I am overlooking?
Craig
try and consolidate all policers into one policy:
class-map VLAN_1007_CLASS
match vlan 1007
class-map VLAN_1008_CLASS
match vlan 1008
class-map VLAN_1009_CLASS
match vlan 1009
policy-map VLAN_POLICY
class VLAN_1007_CLASS
police 20m
class VLAN_1008_CLASS
police 50m
class VLAN_1009_CLASS
police 100m
interface GigabitEthernet 1/0/5
service-policy input VLAN_POLICY
Also, if possible, try and use shapers instead of policers, as shapers usually smooth out traffic bursts, while policers can abruptly drop excess traffic:
match vlan 1007
match vlan 1008
match vlan 1009
shape average 20000000
shape average 50000000
shape average 100000000
