Pfr confusion
Jonn cos
Level 4
Level 4
Hi all,
We are currently planning to deploy pfr in our environment. The ios that is currently being used is 12.4(15) on core 3845 router. i have read in my research that this ios version requires BGP or static routing only for the prefixes as shown below
OER BR ACTIVE PROBE: Neither BGP nor Static next hop found during stats lookup
But we are using ospf in our environment. So in order to work on the prefixes that are in routing table as ospf routes, is there anyway to workaround above issue ?
Joseph W. Doherty
Disclaimer
The   Author of this posting offers the information contained within this   posting without consideration and with the reader's understanding that   there's no implied or expressed suitability or fitness for any purpose.   Information provided is for informational purposes only and should not   be construed as rendering professional advice of any kind. Usage of  this  posting's information is solely at reader's own risk.
Liability Disclaimer
In   no event shall Author be liable for any damages whatsoever (including,   without limitation, damages for loss of use, data or profit) arising  out  of the use or inability to use the posting's information even if  Author  has been advised of the possibility of such damage.
Posting
If you want to influence OSPF directly, believe, you'll want an IOS version that supports PIRO.
A workaround might be using static routing.  Years ago, I set up a pair of 3660 Internet edge routers, using 12.4 something and its OER (and OSPF on the interior side).  I remember I used just a static route and OER dynamically injected to-Internet routes.  Don't recall whether I was running BGP between the pair of 3660s.  Do recall I no longer BGP peered with the ISP routers.
So what I'm thinking, if you can get the injected routes with a better AD then OSPF routes, it might work without PIRO.  However, again, on the external side, I only relied on the static default, so it's not exactly the same situation.
