Ping Issues
ameyasingh
I have VLAN’s 1 and 2 that are routable. Both VLAN’s are getting IP addresses via DHCP.
DHCP Scope 1 is servicing building 1 on VLAN 1 – 192.168.1.1-254.
DHCP Scope 2 is servicing building 2 on VLAN 2 – 192.168.2.1-254.
Sitting in building 1, on VLAN 1, I can ping addresses on VLAN 2 in both buildings.
Sitting in building 1, on VLAN 2, I can ping addresses only on VLAN 2 in building 1. However, I am unable to ping addresses on VLAN 2 in building 2 from building 1. The output of the ping is "Reply from x.x.x.x: Destination Host Unreachable"., where x.x.x.x is my local host. Please help.
10 Replies 10
Alex Pfeil
Level 7
Level 7
What is the configuration on the ports connecting the two buildings?
please show interface running configuration and the trunk information connecting the buildings.
show run interface
show int "INTERFACE" trunk
Hi Alex,
Here is the info that you requested:
Switch1#sh run interface gi0/24
Building configuration...
Current configuration : 87 bytes
interface GigabitEthernet0/24
switchport mode trunk
end
Switch1#sh int gi0/24 trunk
Port       Mode   Encapsulation    Status     Native vlan
Gi0/24     on           802.1q         trunking             1
Port                   Vlans allowed on trunk
Gi0/24                   1-4094
Port                   Vlans allowed and active in management domain
Gi0/24                   1,2
Port                   Vlans in spanning tree forwarding state and not pruned
Gi0/24                   1,2
Switch2#sh run interface gi0/6
Current configuration : 167 bytes
interface GigabitEthernet0/6
storm-control broadcast level 70.00
end
Switch2#sh int gi0/6 trunk
Gi0/6      on          802.1q        trunking        1
Gi0/6                          1-4094
Gi0/6                          1,2
Gi0/6                          1,2
It's a P2P connection between the buildings.
balaji.bandi
1. what is these devices and mode which in the building 1 and 2
2. what kind of connectivity between buildings
3. is the building to building switch port configured as trunk and allow vlan 1 and 2 ?
4. also post the configuration of the interfaces connected between building
BB
Hi Balaji,
1. These are Cisco Catalyst switches.
2. It's a P2P connection between the buildings.
3.
end
Gi0/24                   1-4094
Gi0/24                   1,2
Gi0/24                   1,2
end
Gi0/6                          1-4094
Gi0/6                          1,2
Gi0/6                          1,2
ok please post L3 SVI interface configuration from both the switches.
show run interface vlan 1
show run interface vlan 2
show ip route
BB
When I try to ping 192.168.2.x in building 2 from 192.168.2.x in building 1, sometimes I get the result as "Reply from 192.168.2.x(my local host): Destination host unreachable" and sometimes as "Request Timed Out". Both the buildings are being serviced by different DHCP scopes using AD (In building 1, DHCP scope is defined as - 1,2 - all devices in building 1 are primarily given IP address in VLAN 1 and in building 2 it is defined as - 2,1 - all devices in building 2 are primarily given IP address in VLAN 2). Does that make a difference.
Hello
Please can you post the running config from the core switch and access switch pertaining to these two buildings?
Also include:
sh int trunk
sh vlan brief
Kind Regards
Paul
Hi Paul,
Here are the configs:
Hi Alex,
end
Gi0/24                   1-4094
Gi0/24                   1,2
Gi0/24                   1,2
end
Gi0/6                          1-4094
Gi0/6                          1,2
Gi0/6                          1,2
Hello
Can you post the config if thr L3 and also if applicable the access switchs
Kind Regards
Paul
