Ping Problem
C_G
Good morning everyone,
I created a small network(beginner), everything seems ok but I can't ping.
Can anyone please address me in the right direction to solve the problem?
Thanks in advance
@C_G
Do you modified as I suggested ?
Best regards
7 Replies 7
M02@rt37
Hello @C_G
On Switches 1 and 2 configure Gig0/1 like this:
On Router1 there is a mistake between Giga0/0/0 and 0/0/1 as concerned IP ADDRESS and the global confoguration also.
These interfaces have to be configured with sub-interfaces like this (note that I invert IP between interfaces also):
PC0 should be able to ping PC1 now.
Best regards
Georg Pauwen
what are the device passwords ? Can you unlock the logical view ?
Hello @Georg Pauwen
No need password
Clic first on config tab, select one interface, and go back to CLI !
Best regards
Hi, unfortunately I can't, has being blocked by the tutor(just an exercise
not an assessment). The passwords are torinopiemonte for the line and
torinosecret for the secret.
Giuseppe
@C_G
Best regards
Hi MO2, thanks very much for your help.
Appreciated it
You're so welcome @C_G
Best regards
