Highlighted
Beginner
Please Help - Only Some Port Forwards Working
Hi all,
I have the most annoying issue with a Cisco 887VA-K9 port forwarding. Some port work while other don’t and I just can’t see why, however I suspect it is a zone based firewall (ZBF) issue.
Port forwards on the follow ports all work fine:
External port 8021 to 192.168.4.253 on port 80 works
External port 8022 to 192.168.4.253 on port 8022 works
All the rest don’t. I also have SIP phones sitting outside the LAN which are unable to register through the internet with the PBX unit which is in the DMZ network 192.168.4..0
Any help would be great appreciated as this sending me mad. Fully running config below.
Louise ;-)
Building configuration...
Current configuration : 36870 bytes
! Last configuration change at 12:49:03 Magadan Fri Nov 8 2013 by cpadmin
version 15.1
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
service sequence-numbers
hostname QQQ_ADSL_Gateway
boot-start-marker
boot-end-marker
security authentication failure rate 3 log
security passwords min-length 6
logging buffered 64000
enable secret 4 gim.lMOdQK/21R4Wu.QJfOMAv3CIkRyN.hbSTG5xAxE
aaa new-model
aaa authentication login local_authen local
aaa authentication login ciscocp_vpn_xauth_ml_1 local
aaa authorization exec local_author local
aaa authorization network ciscocp_vpn_group_ml_1 local
aaa session-id common
memory-size iomem 10
clock timezone Magadan 11 0
crypto pki trustpoint TP-self-signed-3471381936
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-3471381936
revocation-check none
rsakeypair TP-self-signed-3471381936
crypto pki trustpoint test_trustpoint_config_created_for_sdm
subject-name e=sdmtest@sdmtest.com
revocation-check crl
crypto pki certificate chain TP-self-signed-3471381936
certificate self-signed 01
  3082022B 30820194 A0030201 02020101 300D0609 2A864886 F70D0101 05050030
  31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 33343731 33383139 3336301E 170D3132 30373132 31313332
  34375A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
  4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D33 34373133
  38313933 3630819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
  8100AB76 5F7EE03F 306F52A0 91E82E04 7A69528D 1839409C 55BCC55A 47F180A9
  7B522E9B FBB96A32 715178FE B96B737E 788947A4 CF4791AA 15609E37 A3F66F07
  AD1B8A34 A2877711 E33A613D 8E50AE40 A106DE9C B2B03B95 73392ADB 4BB51FAD
  6F2D6F8D A90BA0B5 BD1A209C F54126A9 2E2FF5B7 85041B7E C72032C0 CECE7F79
  51550203 010001A3 53305130 0F060355 1D130101 FF040530 030101FF 301F0603
  551D2304 18301680 141713AB B7F927E5 50C242DF 9912C3B6 61D93313 80301D06
  03551D0E 04160414 1713ABB7 F927E550 C242DF99 12C3B661 D9331380 300D0609
  2A864886 F70D0101 05050003 81810099 8EBE5630 2E6734A8 4D2FD0A5 F09A98F8
  9E49125F AECEF4BB E0DEBB3A 1A449E38 99B02114 7EC84845 B53C2F88 046B7290
  AE44967A 8BE20F5E 9D4A1CFC E1F64FE8 59F51892 23B88B4E 3416808A 68E65660
  644C7DA0 E3A7A525 14FE8E54 67C35F8E CF69EB40 34DFB13D EA302F66 102C822A
  3D7107BA AA4E7273 1D43690E C4A5D4
                quit
crypto pki certificate chain test_trustpoint_config_created_for_sdm
no ip source-route
ip dhcp excluded-address 192.168.0.230 192.168.0.255
ip dhcp excluded-address 192.168.0.1 192.168.0.200
ip dhcp pool QQQ_LAN
import all
network 192.168.0.0 255.255.255.0
default-router 192.168.0.254
dns-server 192.168.0.6 202.1.161.36
netbios-name-server 192.168.0.6
domain-name QQQ.Local
lease 3
ip cef
no ip bootp server
ip domain name QQQ.Local
ip name-server 192.168.0.6
ip name-server 202.1.161.37
ip name-server 202.1.161.36
ip inspect log drop-pkt
no ipv6 cef
parameter-map type inspect global
log dropped-packets enable
parameter-map type protocol-info yahoo-servers
server name scs.msg.yahoo.com
server name scsa.msg.yahoo.com
server name scsb.msg.yahoo.com
server name scsc.msg.yahoo.com
server name scsd.msg.yahoo.com
server name cs16.msg.dcn.yahoo.com
server name cs19.msg.dcn.yahoo.com
server name cs42.msg.dcn.yahoo.com
server name cs53.msg.dcn.yahoo.com
server name cs54.msg.dcn.yahoo.com
server name ads1.vip.scd.yahoo.com
server name radio1.launch.vip.dal.yahoo.com
server name in1.msg.vip.re2.yahoo.com
server name data1.my.vip.sc5.yahoo.com
server name address1.pim.vip.mud.yahoo.com
server name edit.messenger.yahoo.com
server name messenger.yahoo.com
server name http.pager.yahoo.com
server name privacy.yahoo.com
server name csa.yahoo.com
server name csb.yahoo.com
server name csc.yahoo.com
parameter-map type protocol-info aol-servers
server name login.oscar.aol.com
server name toc.oscar.aol.com
server name oam-d09a.blue.aol.com
parameter-map type protocol-info msn-servers
server name messenger.hotmail.com
server name gateway.messenger.hotmail.com
server name webmessenger.msn.com
password encryption aes
license udi pid CISCO887VA-K9 sn FGL162321CT
object-group service MAIL-PORTS
description QQQ User Mail Restrictions
tcp eq smtp
tcp eq pop3
tcp eq 995
tcp eq 993
udp lt rip
udp lt domain
tcp eq telnet
udp lt ntp
udp lt tftp
tcp eq ftp
tcp eq domain
tcp eq 5900
tcp eq ftp-data
tcp eq 3389
tcp eq 20410
object-group network Network1
description QQQ Management Network
192.168.1.0 255.255.255.0
192.168.4.0 255.255.255.0
192.168.5.0 255.255.255.0
192.168.7.0 255.255.255.0
192.168.8.0 255.255.255.0
range 192.168.0.200 192.168.0.254
range 192.168.0.1 192.168.0.25
object-group network Network2
description QQQ User Network
192.168.2.0 255.255.255.0
192.168.3.0 255.255.255.0
192.168.6.0 255.255.255.0
range 192.168.0.26 192.168.0.199
object-group network QQQ.Local
description QQQ_Domain
192.168.10.0 255.255.255.0
10.1.0.0 255.255.0.0
object-group network QQQ_Management_Group
description QQQ I.T. Devices With UnRestricted Access
10.8.0.0 255.255.255.0
192.168.9.0 255.255.255.0
192.168.100.0 255.255.255.0
192.168.20.0 255.255.255.0
192.168.21.0 255.255.255.0
192.168.22.0 255.255.255.0
192.168.23.0 255.255.255.0
object-group network QQQ_User_Group
description QQQ I.T. Devices WIth Restricted Access
object-group service WEB
description QQQ User Web Restrictions
tcp eq www
tcp eq 443
tcp eq 8080
tcp eq 1863
tcp eq 5190
username cpadmin privilege 15 password 7 1406031A2C172527
username QQQVPN privilege 15 secret 4 Hk2tP2GgJ1xXtJUqIZr4gmNSgw6q1E.rvzWiYnDAZHU
controller VDSL 0
ip tcp synwait-time 10
no ip ftp passive
class-map type inspect match-all sdm-cls-VPNOutsideToInside-1
match access-group 118
class-map type inspect match-all sdm-cls-VPNOutsideToInside-3
match access-group 121
class-map type inspect match-all sdm-cls-VPNOutsideToInside-2
match access-group 120
class-map type inspect imap match-any ccp-app-imap
match  invalid-command
class-map type inspect match-any ccp-cls-protocol-p2p
match protocol edonkey signature
match protocol gnutella signature
match protocol kazaa2 signature
match protocol fasttrack signature
match protocol bittorrent signature
class-map type inspect match-all sdm-cls-VPNOutsideToInside-4
match access-group 122
class-map type inspect match-all SDM_GRE
match access-group name SDM_GRE
class-map type inspect match-any CCP_PPTP
match class-map SDM_GRE
class-map type inspect match-any SDM_AH
match access-group name SDM_AH
class-map type inspect match-any ccp-skinny-inspect
match protocol skinny
class-map type inspect match-any SDM_ESP
match access-group name SDM_ESP
class-map type inspect match-any SDM_VPN_TRAFFIC
match protocol isakmp
match protocol ipsec-msft
match class-map SDM_AH
match class-map SDM_ESP
class-map type inspect match-all SDM_VPN_PT
match access-group 117
match class-map SDM_VPN_TRAFFIC
class-map type inspect match-any ccp-cls-insp-traffic
match protocol pptp
match protocol dns
match protocol ftp
match protocol https
match protocol icmp
match protocol imap
match protocol pop3
match protocol netshow
match protocol shell
match protocol realmedia
match protocol rtsp
match protocol smtp
match protocol sql-net
match protocol streamworks
match protocol tftp
match protocol vdolive
match protocol tcp
match protocol udp
class-map type inspect match-all ccp-insp-traffic
match class-map ccp-cls-insp-traffic
class-map type inspect match-any SDM_IP
match access-group name SDM_IP
class-map type inspect gnutella match-any ccp-app-gnutella
match  file-transfer
class-map type inspect match-any SDM_HTTP
match access-group name SDM_HTTP
class-map type inspect match-any SDM_EASY_VPN_SERVER_TRAFFIC
class-map type inspect match-all SDM_EASY_VPN_SERVER_PT
match class-map SDM_EASY_VPN_SERVER_TRAFFIC
class-map type inspect match-all sdm-cls-http
match access-group name dmz-traffic
match protocol http
class-map type inspect match-any Telnet
match protocol telnet
class-map type inspect msnmsgr match-any ccp-app-msn-otherservices
match  service any
class-map type inspect ymsgr match-any ccp-app-yahoo-otherservices
match  service any
class-map type inspect match-any ccp-h323nxg-inspect
match protocol h323-nxg
class-map type inspect match-any ccp-cls-icmp-access
match protocol icmp
match protocol tcp
match protocol udp
class-map type inspect match-any ccp-cls-protocol-im
match protocol ymsgr yahoo-servers
match protocol msnmsgr msn-servers
match protocol aol aol-servers
class-map type inspect aol match-any ccp-app-aol-otherservices
match  service any
class-map type inspect match-all ccp-protocol-pop3
match protocol pop3
class-map type inspect match-any ccp-h225ras-inspect
match protocol h225ras
class-map type inspect match-any FIREWALL_EXCEPTIONS_CLASS
match access-group name FIREWALL_EXCEPTIONS_ACL
class-map type inspect match-any ccp-h323annexe-inspect
match protocol h323-annexe
class-map type inspect match-any SDM_EASY_VPN_CTCP_SERVER_PT
match access-group 102
match access-group 103
match access-group 104
match access-group 105
match access-group 106
match access-group 107
match access-group 108
match access-group 109
match access-group 110
match access-group 111
match access-group 112
match access-group 113
match access-group 114
match access-group 115
class-map type inspect match-any SIP
match protocol sip
class-map type inspect pop3 match-any ccp-app-pop3
class-map type inspect match-any SDM_HTTPS
match access-group name SDM_HTTPS
class-map type inspect sip match-any ccp-cls-sip-pv-2
match  protocol-violation
class-map type inspect kazaa2 match-any ccp-app-kazaa2
match  file-transfer
class-map type inspect match-all ccp-protocol-p2p
match class-map ccp-cls-protocol-p2p
class-map type inspect match-all ccp-cls-ccp-permit-1
match access-group name ETS1
class-map type inspect match-any ccp-h323-inspect
match protocol h323
match  service text-chat
class-map type inspect match-all ccp-cls-ccp-pol-outToIn-1
class-map type inspect match-all ccp-protocol-im
match class-map ccp-cls-protocol-im
class-map type inspect match-all ccp-cls-ccp-pol-outToIn-2
match class-map Telnet
match access-group name Telnet
class-map type inspect match-all ccp-icmp-access
match class-map ccp-cls-icmp-access
class-map type inspect match-all ccp-invalid-src
match access-group 100
class-map type inspect http match-any ccp-app-httpmethods
match  request method bcopy
match  request method bdelete
match  request method bmove
match  request method bpropfind
match  request method bproppatch
match  request method connect
match  request method copy
match  request method delete
match  request method edit
match  request method getattribute
match  request method getattributenames
match  request method getproperties
match  request method index
match  request method lock
match  request method mkcol
match  request method mkdir
match  request method move
match  request method notify
match  request method options
match  request method poll
match  request method propfind
match  request method proppatch
match  request method put
match  request method revadd
match  request method revlabel
match  request method revlog
match  request method revnum
match  request method save
match  request method search
match  request method setattribute
match  request method startrev
match  request method stoprev
match  request method subscribe
match  request method trace
match  request method unedit
match  request method unlock
match  request method unsubscribe
class-map type inspect match-any ccp-dmz-protocols
match user-group qqq
match protocol icmp
match protocol http
class-map type inspect edonkey match-any ccp-app-edonkey
match  file-transfer
match  text-chat
match  search-file-name
class-map type inspect match-any ccp-sip-inspect
match protocol sip
class-map type inspect match-all sdm-cls-sip
match protocol sip
class-map type inspect match-all ccp-dmz-traffic
match class-map ccp-dmz-protocols
class-map type inspect http match-any ccp-http-blockparam
match  request port-misuse im
match  request port-misuse p2p
class-map type inspect edonkey match-any ccp-app-edonkeydownload
match  file-transfer
class-map type inspect match-all ccp-protocol-imap
match protocol imap
class-map type inspect edonkey match-any ccp-app-edonkeychat
match  text-chat
class-map type inspect match-all ccp-cls-ccp-permit-dmzservice-1
match class-map SIP
match access-group name SIP
class-map type inspect fasttrack match-any ccp-app-fasttrack
match  file-transfer
class-map type inspect http match-any ccp-http-allowparam
match  request port-misuse tunneling
class-map type inspect match-all ccp-protocol-http
match protocol http
policy-map type inspect ccp-permit-icmpreply
class type inspect ccp-icmp-access
  inspect
class class-default
  pass
policy-map type inspect p2p ccp-action-app-p2p
class type inspect edonkey ccp-app-edonkeychat
  log
  allow
class type inspect edonkey ccp-app-edonkeydownload
  log
  allow
class type inspect fasttrack ccp-app-fasttrack
  log
  allow
class type inspect gnutella ccp-app-gnutella
  log
  allow
class type inspect kazaa2 ccp-app-kazaa2
  log
  allow
policy-map type inspect PF_OUT_TO_IN
class type inspect FIREWALL_EXCEPTIONS_CLASS
  pass
policy-map type inspect PF_IN_TO_OUT
  pass
policy-map type inspect im ccp-action-app-im
class type inspect aol ccp-app-aol
  log
  allow
class type inspect msnmsgr ccp-app-msn
  log
  allow
class type inspect ymsgr ccp-app-yahoo
  log
  allow
class type inspect aol ccp-app-aol-otherservices
  log
  reset
class type inspect msnmsgr ccp-app-msn-otherservices
  log
  reset
class type inspect ymsgr ccp-app-yahoo-otherservices
  log
  reset
policy-map type inspect http ccp-action-app-http
class type inspect http ccp-http-blockparam
  log
  reset
class type inspect http ccp-app-httpmethods
  log
  reset
class type inspect http ccp-http-allowparam
  log
  allow
policy-map type inspect imap ccp-action-imap
class type inspect imap ccp-app-imap
  log
policy-map type inspect pop3 ccp-action-pop3
class type inspect pop3 ccp-app-pop3
  log
policy-map type inspect ccp-inspect
class type inspect ccp-protocol-http
  inspect
  service-policy http ccp-action-app-http
class type inspect ccp-protocol-imap
  inspect
  service-policy imap ccp-action-imap
class type inspect ccp-protocol-pop3
  inspect
  service-policy pop3 ccp-action-pop3
class type inspect ccp-protocol-p2p
  inspect
  service-policy p2p ccp-action-app-p2p
  inspect
  service-policy im ccp-action-app-im
class type inspect ccp-insp-traffic
  inspect
class type inspect ccp-sip-inspect
  inspect
class type inspect ccp-h323-inspect
  inspect
class type inspect ccp-h323annexe-inspect
  inspect
class type inspect ccp-h225ras-inspect
  inspect
class type inspect ccp-h323nxg-inspect
  inspect
class type inspect ccp-skinny-inspect
  inspect
class type inspect ccp-invalid-src
  drop log
class class-default
  drop
class type inspect SDM_VPN_PT
  pass
class type inspect ccp-cls-ccp-permit-1
  pass
class type inspect SDM_EASY_VPN_SERVER_PT
  pass
class type inspect SDM_EASY_VPN_CTCP_SERVER_PT
  inspect
class class-default
  drop
policy-map type inspect sip ccp-app-sip-2
class type inspect sip ccp-cls-sip-pv-2
  allow
policy-map type inspect ccp-permit-dmzservice
class type inspect ccp-cls-ccp-permit-dmzservice-1
  pass
class type inspect ccp-dmz-traffic
  inspect
class type inspect sdm-cls-http
  inspect
class type inspect sdm-cls-VPNOutsideToInside-1
  inspect
class type inspect sdm-cls-VPNOutsideToInside-2
  inspect
class type inspect sdm-cls-VPNOutsideToInside-3
  pass
class class-default
  pass
policy-map type inspect ccp-pol-outToIn
class type inspect ccp-cls-ccp-pol-outToIn-1
  pass
class type inspect ccp-cls-ccp-pol-outToIn-2
  pass
class type inspect CCP_PPTP
  pass
  inspect
  inspect
  pass
class type inspect sdm-cls-VPNOutsideToInside-4
  inspect
class class-default
  drop log
policy-map type inspect sdm-permit-ip
class type inspect SDM_IP
  pass
  inspect
  pass
  inspect
class class-default
  drop log
zone security dmz-zone
zone security in-zone
zone security out-zone
zone security ezvpn-zone
zone-pair security ccp-zp-out-dmz source out-zone destination dmz-zone
service-policy type inspect ccp-permit-dmzservice
zone-pair security ccp-zp-out-self source out-zone destination self
zone-pair security ccp-zp-in-out source in-zone destination out-zone
service-policy type inspect ccp-inspect
zone-pair security ccp-zp-out-zone-To-in-zone source out-zone destination in-zone
service-policy type inspect ccp-pol-outToIn
zone-pair security ccp-zp-in-dmz source in-zone destination dmz-zone
zone-pair security ccp-zp-self-out source self destination out-zone
service-policy type inspect ccp-permit-icmpreply
zone-pair security dmz-to-in source dmz-zone destination in-zone
zone-pair security sdm-zp-ezvpn-out1 source ezvpn-zone destination out-zone
service-policy type inspect sdm-permit-ip
zone-pair security sdm-zp-in-ezvpn2 source in-zone destination ezvpn-zone
zone-pair security sdm-zp-in-ezvpn1 source dmz-zone destination ezvpn-zone
zone-pair security sdm-zp-ezvpn-in2 source ezvpn-zone destination in-zone
zone-pair security sdm-zp-ezvpn-in1 source ezvpn-zone destination dmz-zone
zone-pair security sdm-zp-out-ezpn1 source out-zone destination ezvpn-zone
zone-pair security sdm-zp-ezvpn-in3 source ezvpn-zone destination ezvpn-zone
crypto ctcp port 10000 1723 6299
crypto isakmp policy 1
encr 3des
authentication pre-share
group 2
crypto isakmp policy 2
encr aes 256
group 2
crypto isakmp key 6 PbKM_WfaCM[hYNXAFOUgCNgCB_ZdJEAAB address 220.245.109.219
crypto isakmp key 6 NddQRR[O^KY`GRDC[VZUEPE`CSJ^CDAAB address 0.0.0.0 0.0.0.0
crypto isakmp client configuration group QQQ
key 6 UWVBhb`Lgc_AZbDYWDFZiGZTTadNYTAAB
dns 192.168.0.6 202.1.161.36
wins 192.168.0.6
domain QQQ.Local
pool SDM_POOL_1
include-local-lan
max-users 20
max-logins 1
netmask 255.255.255.0
banner ^CCWelcome to QQQ VPN!!!!1                 ^C
crypto isakmp profile ciscocp-ike-profile-1
   match identity group QQQ
   client authentication list ciscocp_vpn_xauth_ml_1
   isakmp authorization list ciscocp_vpn_group_ml_1
   client configuration address initiate
   client configuration address respond
   keepalive 10 retry 2
   virtual-template 1
crypto ipsec transform-set ESP_AES_SHA esp-aes 256 esp-sha-hmac
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec profile CiscoCP_Profile1
set security-association idle-time 43200
set transform-set ESP_AES_SHA
set isakmp-profile ciscocp-ike-profile-1
crypto map SDM_CMAP_1 1 ipsec-isakmp
description Tunnel to220.245.109.219
set peer 220.245.109.219
set transform-set ESP-3DES-SHA
match address 119
interface Loopback0
description QQQ_VPN
ip address 192.168.9.254 255.255.255.0
interface Null0
no ip unreachables
interface Ethernet0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
shutdown
no fair-queue
interface ATM0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
no atm ilmi-keepalive
interface ATM0.1 point-to-point
description Telekom_ADSL
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
zone-member security out-zone
pvc 8/35
  pppoe-client dial-pool-number 1
interface FastEthernet0
description QQQ_LAN-VLAN_1
switchport access vlan 1
no ip address
interface FastEthernet1
no ip address
interface FastEthernet2
description QQQ_WAN-VLAN_2
switchport access vlan 2
no ip address
interface FastEthernet3
description QQQ_DMZ-IP_PBX-VLAN_3
switchport access vlan 3
no ip address
interface Virtual-Template1 type tunnel
description QQQ_Easy_VPN
ip unnumbered Loopback0
ip nat inside
ip virtual-reassembly in
zone-member security ezvpn-zone
tunnel mode ipsec ipv4
tunnel protection ipsec profile CiscoCP_Profile1
interface Vlan1
description QQQ_LAN-VLAN1$FW_INSIDE$
ip address 192.168.0.254 255.255.255.0
ip access-group QQQ_ACL in
ip mask-reply
ip nat inside
zone-member security in-zone
ip tcp adjust-mss 1412
interface Vlan2
description QQQ_WAN-VLAN2$FW_INSIDE$
ip address 192.168.5.254 255.255.255.0
ip mask-reply
ip nat inside
interface Vlan3
description QQQ_IP-PBX_WAN-VLAN3
ip address 192.168.4.254 255.255.255.0
ip mask-reply
ip nat inside
zone-member security dmz-zone
interface Vlan4
description VLAN4 - 192.168.20.xxx (Spare)
ip address 192.168.20.253 255.255.255.0
ip nat inside
interface Dialer0
description ATM Dialer
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip nat outside
no cdp enable
interface Dialer2
description $FW_OUTSIDE$
ip address negotiated
no ip redirects
no ip unreachables
no ip proxy-arp
ip mtu 1452
ip nbar protocol-discovery
ip flow ingress
ip flow egress
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication chap pap callin
ppp chap hostname xxxxxxxxxxxxxxxxxxx
ppp chap password 7 xxxxxxxxxxxxxxxxxxxxxxxxx
ppp pap sent-username xxxxxxxxxx0 password 7 xxxxxxxxxxxxxxxxxxxxx
no cdp enable
router rip
version 2
redistribute static
passive-interface ATM0
passive-interface ATM0.1
passive-interface Dialer0
passive-interface Dialer2
passive-interface Ethernet0
passive-interface Loopback0
network 10.0.0.0
network 192.168.0.0
network 192.168.1.0
network 192.168.2.0
network 192.168.3.0
network 192.168.4.0
network 192.168.5.0
network 192.168.6.0
network 192.168.7.0
network 192.168.8.0
network 192.168.10.0
network 192.168.100.0
ip local pool SDM_POOL_1 192.168.5.100 192.168.5.200
ip forward-protocol nd
ip http server
ip http access-class 5
ip http authentication local
ip http secure-server
ip nat pool NAT_IP 192.168.0.210 192.168.0.235 netmask 255.255.255.0
ip nat inside source static tcp 192.168.4.253 5060 interface Dialer2 5060
ip nat inside source static tcp 192.168.0.240 20408 interface Dialer2 6208
ip nat inside source static tcp 192.168.0.240 20409 interface Dialer2 6209
ip nat inside source static tcp 192.168.0.240 20410 interface Dialer2 6200
ip nat inside source static tcp 192.168.1.240 20408 interface Dialer2 6218
ip nat inside source static tcp 192.168.1.240 20409 interface Dialer2 6219
ip nat inside source static tcp 192.168.1.240 20410 interface Dialer2 6210
ip nat inside source static tcp 192.168.7.240 20408 interface Dialer2 6278
ip nat inside source static tcp 192.168.7.240 20409 interface Dialer2 6279
ip nat inside source static tcp 192.168.7.240 20410 interface Dialer2 6270
ip nat inside source static tcp 192.168.8.240 20408 interface Dialer2 6288
ip nat inside source static tcp 192.168.8.240 20409 interface Dialer2 6289
ip nat inside source static tcp 192.168.8.240 20410 interface Dialer2 6280
ip nat inside source static tcp 192.168.0.6 1723 interface Dialer2 1723
ip nat inside source static tcp 192.168.0.6 3389 interface Dialer2 6389
ip nat inside source static tcp 192.168.0.24 3389 interface Dialer2 6390
ip nat inside source static tcp 192.168.4.253 8022 interface Dialer2 8022
ip nat inside source static tcp 192.168.4.253 80 interface Dialer2 8021
ip nat inside source static tcp 192.168.0.254 23 interface Dialer2 8023
ip nat inside source static tcp 192.168.0.6 443 interface Dialer2 443
ip nat inside source route-map SDM_RMAP_1 interface Dialer2 overload
ip default-network 192.168.0.0
ip default-network 192.168.4.0
ip route 0.0.0.0 0.0.0.0 Dialer2 permanent
ip route 10.1.0.0 255.255.0.0 Vlan2 permanent
ip route 10.8.0.0 255.255.255.0 Vlan2 permanent
ip route 192.168.0.0 255.255.255.0 Vlan1 permanent
ip route 192.168.4.0 255.255.255.0 Vlan3 permanent
ip route 192.168.5.0 255.255.255.0 Vlan2 permanent
ip route 192.168.100.0 255.255.255.0 Dialer2 permanent
ip access-list extended ACCESS_FROM_INSIDE
permit ip object-group QQQ_Management_Group any
permit tcp object-group QQQ_User_Group any eq smtp pop3
permit tcp object-group QQQ_User_Group any eq 993 995
permit tcp 192.168.0.0 0.0.0.255 any eq smtp pop3
permit tcp 192.168.0.0 0.0.0.255 any eq 993 995
permit ip 192.168.1.0 0.0.0.255 any
permit ip 192.168.4.0 0.0.0.255 any
permit ip 192.168.5.0 0.0.0.255 any
permit ip 192.168.7.0 0.0.0.255 any
permit ip 192.168.8.0 0.0.0.255 any
permit tcp 192.168.2.0 0.0.0.255 any eq www 443 8080 domain
permit tcp 192.168.2.0 0.0.0.255 any eq www 443 8080 domain time-range QQQ_Control
permit tcp 192.168.3.0 0.0.0.255 any eq www 443 8080 domain time-range QQQ_Control
permit tcp 192.168.4.0 0.0.0.255 any eq www 443 8080 domain time-range QQQ_Control
permit udp 192.168.2.0 0.0.0.255 any eq domain time-range QQQ_Control
permit udp 192.168.3.0 0.0.0.255 any eq domain time-range QQQ_Control
permit udp 192.168.4.0 0.0.0.255 any eq domain time-range QQQ_Control
ip access-list extended ETS
remark CCP_ACL Category=128
permit ip host 203.219.237.252 any
ip access-list extended ETS1
ip access-list extended FIREWALL_EXCEPTIONS_ACL
permit tcp any host 192.168.0.100 eq 25565
permit tcp any eq 25565 host 192.168.0.100
ip access-list extended QQQ_ACL
permit ip any host 192.168.4.253
permit udp any any eq bootps bootpc
permit ip any 192.168.4.0 0.0.0.255
remark QQQ Internet Control List
remark CCP_ACL Category=17
remark Auto generated by CCP for NTP (123) 203.12.160.2
permit udp host 203.12.160.2 eq ntp any eq ntp
remark AD Services
permit udp host 192.168.0.6 eq domain any
remark Unrestricted Access
remark Restricted Users
permit object-group MAIL-PORTS object-group QQQ_User_Group any
permit ip 192.168.0.0 0.0.0.255 any time-range QQQ_Control
permit ip 192.168.2.0 0.0.0.255 any time-range QQQ_Control
permit ip 192.168.3.0 0.0.0.255 any time-range QQQ_Control
permit ip 192.168.6.0 0.0.0.255 any time-range QQQ_Control
remark ICMP Full Access
permit icmp object-group QQQ_User_Group any
permit tcp 192.168.2.0 0.0.0.255 eq www 443 8080 5190 1863 any time-range QQQ_Control
permit tcp 192.168.3.0 0.0.0.255 eq www 443 8080 5190 1863 any time-range QQQ_Control
permit tcp 192.168.6.0 0.0.0.255 eq www 443 8080 5190 1863 any time-range QQQ_Control
permit udp 192.168.6.0 0.0.0.255 eq 80 443 8080 5190 1863 any time-range QQQ_Control
permit tcp 192.168.0.0 0.0.0.255 eq www 443 8080 5190 1863 any time-range QQQ_Control
permit udp 192.168.0.0 0.0.0.255 eq 80 443 8080 5190 1863 any time-range QQQ_Control
permit udp 192.168.2.0 0.0.0.255 eq 80 443 8080 5190 1863 any time-range QQQ_Control
permit udp 192.168.3.0 0.0.0.255 eq 80 443 8080 5190 1863 any time-range QQQ_Control
ip access-list extended QQQ_NAT
remark CCP_ACL Category=18
remark IPSec Rule
deny   ip 192.168.0.0 0.0.255.255 192.168.100.0 0.0.0.255
permit ip any any
ip access-list extended SDM_AH
permit ahp any any
ip access-list extended SDM_ESP
permit esp any any
ip access-list extended SDM_GRE
permit gre any any
ip access-list extended SDM_HTTP
remark CCP_ACL Category=0
permit tcp any any eq telnet
ip access-list extended SDM_HTTPS
permit tcp any any eq 443
ip access-list extended SDM_IP
permit ip any any
ip access-list extended SIP
ip access-list extended Telnet
permit ip any any
ip access-list extended dmz-traffic
access-list 1 remark CCP_ACL Category=2
access-list 1 remark QQQ_DMZ
access-list 1 permit 192.168.4.0 0.0.0.255
access-list 2 remark CCP_ACL Category=2
access-list 2 remark QQQ_LAN
access-list 2 permit 192.168.0.0 0.0.0.255
access-list 3 remark QQQ Insid NAT
access-list 3 remark CCP_ACL Category=2
access-list 3 permit 192.168.0.0 0.0.0.255
access-list 3 permit 192.168.1.0 0.0.0.255
access-list 3 permit 192.168.2.0 0.0.0.255
access-list 3 permit 192.168.3.0 0.0.0.255
access-list 3 permit 192.168.4.0 0.0.0.255
access-list 3 permit 192.168.5.0 0.0.0.255
access-list 3 permit 192.168.6.0 0.0.0.255
access-list 3 permit 192.168.7.0 0.0.0.255
access-list 3 permit 192.168.8.0 0.0.0.255
access-list 3 permit 192.168.9.0 0.0.0.255
access-list 3 permit 192.168.10.0 0.0.0.255
access-list 4 remark QQQ_NAT
access-list 4 remark CCP_ACL Category=2
access-list 4 permit 10.1.0.0 0.0.255.255
access-list 4 permit 10.8.0.0 0.0.0.255
access-list 4 permit 192.168.0.0 0.0.0.255
access-list 4 permit 192.168.1.0 0.0.0.255
access-list 4 permit 192.168.2.0 0.0.0.255
access-list 4 permit 192.168.3.0 0.0.0.255
access-list 4 permit 192.168.4.0 0.0.0.255
access-list 4 permit 192.168.5.0 0.0.0.255
access-list 4 permit 192.168.6.0 0.0.0.255
access-list 4 permit 192.168.7.0 0.0.0.255
access-list 4 permit 192.168.8.0 0.0.0.255
access-list 4 permit 192.168.9.0 0.0.0.255
access-list 4 permit 192.168.10.0 0.0.0.255
access-list 5 remark HTTP Access-class list
access-list 5 remark CCP_ACL Category=1
access-list 5 permit 192.168.4.0 0.0.0.255
access-list 5 permit 192.168.0.0 0.0.0.255
access-list 5 deny   any
access-list 100 remark CCP_ACL Category=128
access-list 100 permit ip 192.168.4.0 0.0.0.255 any
access-list 100 permit ip 127.0.0.0 0.255.255.255 any
access-list 100 permit ip host 255.255.255.255 any
access-list 101 remark QQQ_Extended_ACL
access-list 101 remark CCP_ACL Category=1
access-list 101 permit tcp any host 192.168.0.254 eq 10000
access-list 101 permit udp any host 192.168.0.254 eq non500-isakmp
access-list 101 permit udp any host 192.168.0.254 eq isakmp
access-list 101 permit esp any host 192.168.0.254
access-list 101 permit ahp any host 192.168.0.254
access-list 101 remark Auto generated by CCP for NTP (123) 203.12.160.2
access-list 101 permit udp host 203.12.160.2 eq ntp host 192.168.4.254 eq ntp
access-list 101 permit udp host 192.168.0.6 eq domain any
access-list 101 remark NTP (123) 203.12.160.2
access-list 101 permit udp host 203.12.160.2 eq ntp any eq ntp
access-list 101 remark QQQ_ANY_Any
access-list 101 permit ip object-group QQQ.Local any
access-list 101 remark QQQ_DMZ
access-list 101 permit ip any 192.168.4.0 0.0.0.255
access-list 101 remark QQQ_GRE
access-list 101 permit gre any any
access-list 101 remark QQQ_Ping
access-list 101 permit icmp any any
access-list 102 remark CCP_ACL Category=1
access-list 102 permit tcp any any eq 10000
access-list 103 permit tcp any 192.168.0.0 0.0.0.255 eq 443
access-list 103 remark CCP_ACL Category=1
access-list 103 permit tcp any any eq 10000
access-list 103 permit tcp any 192.168.4.0 0.0.0.255 eq 8022
access-list 103 permit tcp any 192.168.4.0 0.0.0.255 eq telnet
access-list 103 permit tcp any 192.168.4.0 0.0.0.255 eq www
access-list 103 permit tcp any 192.168.4.0 0.0.0.255 eq 5060
access-list 103 permit tcp any eq telnet host 192.168.0.254
access-list 103 permit tcp any 192.168.0.0 0.0.0.255 eq telnet
access-list 103 permit udp any 192.168.4.0 0.0.0.255 eq 5060
access-list 103 permit udp any 192.168.4.0 0.0.0.255 range 10001 12000
access-list 104 remark CCP_ACL Category=1
access-list 104 permit tcp any any eq 10000
access-list 105 remark CCP_ACL Category=1
access-list 105 permit tcp any any eq 10000
access-list 106 remark CCP_ACL Category=1
access-list 106 permit tcp any any eq 10000
access-list 107 remark CCP_ACL Category=1
access-list 107 permit tcp any any eq 10000
access-list 108 remark CCP_ACL Category=1
access-list 108 permit tcp any any eq 10000
access-list 109 remark CCP_ACL Category=1
access-list 109 permit tcp any any eq 10000
access-list 110 remark CCP_ACL Category=1
access-list 110 permit tcp any any eq 10000
access-list 111 remark CCP_ACL Category=1
access-list 111 permit tcp any any eq 10000
access-list 112 remark CCP_ACL Category=1
access-list 112 permit tcp any any eq 10000
access-list 113 remark CCP_ACL Category=1
access-list 113 permit tcp any any eq 10000
access-list 114 remark CCP_ACL Category=1
access-list 114 permit tcp any any eq 10000
access-list 115 remark CCP_ACL Category=1
access-list 115 permit tcp any any eq 10000
access-list 116 remark CCP_ACL Category=4
access-list 116 remark IPSec Rule
access-list 116 permit ip 192.168.0.0 0.0.255.255 192.168.100.0 0.0.0.255
access-list 117 remark CCP_ACL Category=128
access-list 117 permit ip any any
access-list 117 permit ip host 220.245.109.219 any
access-list 118 remark CCP_ACL Category=0
access-list 118 permit ip 192.168.100.0 0.0.0.255 192.168.0.0 0.0.0.255
access-list 119 remark CCP_ACL Category=4
access-list 119 remark IPSec Rule
access-list 119 permit ip 192.168.0.0 0.0.255.255 192.168.100.0 0.0.0.255
access-list 120 remark CCP_ACL Category=0
access-list 120 permit ip 192.168.100.0 0.0.0.255 192.168.0.0 0.0.0.255
access-list 121 remark CCP_ACL Category=0
access-list 121 permit ip 192.168.100.0 0.0.0.255 192.168.0.0 0.0.255.255
access-list 122 remark CCP_ACL Category=0
access-list 122 permit ip 192.168.100.0 0.0.0.255 192.168.0.0 0.0.255.255
dialer-list 1 protocol ip permit
route-map SDM_RMAP_1 permit 1
match ip address QQQ_NAT
banner login ^CCWelcome to QQQ ADSL Gateway
0 REPLIES 0
Content for Community-Ad
