Please suggest one Gigabyte switch for replacing Cisco 2960 G 48 port
ashikcisco999
Dear all,
Cisco 2960 G is seems to be end of life.Please suggest one switch with same feature of Cisco 2960 G 48 port, with same prize
Ashik A S
9605395605
Bilal Nawaz
What is the budget? How much can be spend on a replacement switch?
Please rate useful posts & remember to mark any solved questions as answered. Thank you.
Dear Bilal,
Budget is also neer to old 2960.
approximately  max120000 RS
Ashik A S
9605395605
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
Have you looked at the newer/current series of 2960s?
