Hi all Cisco experts,
recently I tried installing a WS-X4648-RJ45V+E 10/100/1000 PoE blade into slot 10 of our WS-C4510R-E chassis and it can back with an alert stating the blade is not supported in this slot.
However the WS-X4248-RJ45V 10/100 PoE blade works perfectly well.
Is there a reason for this?
What are my options here?
Many thanks,
Paul
What type of Sup do you have in this switch?
Hi Paul,
What is the Supervisor engine on 4510? Slot 10 is Flex-slot. Below from Cisco docs.
When Catalyst 4000/4500 Supervisor Engine V is used in the Catalyst 4510R chassis, slot 10 (Flex-slot) supports a subset of
line cards: 2-port Gigabit Interface Converter (GBIC) and Access Gateway Module This is because of the switching capacity of the Catalyst 4000/4500 Supervisor Engine V; not a limitation of Catalyst 4510R chassis. The Catalyst 4500 Series Supervisor Engine V-10GE allows slot 10 to accommodate any and all line cards.
Option- if you havr any other spare slot (apart from Sup slots), you can use it.
hth
MS
Hi Guys,
thanks for the speedy responses. Here's the output of the "show module":
Mod Ports Card Type Model Serial No.
1 48 10/100/1000BaseT (RJ45) WS-X4548-GB-RJ45 JAE151407BU
2 48 10/100/1000BaseT (RJ45) WS-X4548-GB-RJ45 JAE151406GM
3 48 10/100/1000BaseT (RJ45) WS-X4548-GB-RJ45 JAE151406KR
4 48 10/100/1000BaseT (RJ45) WS-X4548-GB-RJ45 JAE151406PV
5 6 Sup 6-E 10GE (X2), 1000BaseX (SFP) WS-X45-SUP6-E JAE151008FK
6 6 Sup 6-E 10GE (X2), 1000BaseX (SFP) WS-X45-SUP6-E JAE151008FF
7 48 10/100/1000BaseT (RJ45) WS-X4548-GB-RJ45 JAE151407C7
8 48 10/100/1000BaseT (RJ45) WS-X4548-GB-RJ45 JAE151406KS
9 48 10/100/1000BaseT (RJ45) WS-X4548-GB-RJ45 JAE151406JW
10 48 10/100/1000BaseT (RJ45) WS-X4548-GB-RJ45 JAE151406GN
Am I still restricted?
Paul
For slots 8-10 : I am afraid so. Per Cisco doc- The Cisco Catalyst 4510R-E supports only classic line cards in slots 8 to 10 with Supervisor Engine 6-E. So, I was wrong in my frist reply in terms of 'option'. You may want to move one of classc line card (1-4) to 10 and try POE module in that. More info about line cards...
Thx
MS
Hi again,
and thanks for all your help here it's much appreciated. One last thing, on a similar switch we have 10/100 Poe blades in the 4510 chassis without an issue, are these considered "classic line"?
See below:
Chassis Type : WS-C4510R-E
Power consumed by backplane : 40 Watts
1 48 10/100BaseTX (RJ45)V, Cisco/IEEE WS-X4248-RJ45V JAE15140BCQ
2 48 10/100BaseTX (RJ45)V, Cisco/IEEE WS-X4248-RJ45V JAE151100Y7
3 48 10/100BaseTX (RJ45)V, Cisco/IEEE WS-X4248-RJ45V JAE15140BJU
4 48 10/100BaseTX (RJ45)V, Cisco/IEEE WS-X4248-RJ45V JAE151100U4
5 6 Sup 6-E 10GE (X2), 1000BaseX (SFP) WS-X45-SUP6-E JAE150706BQ
6 6 Sup 6-E 10GE (X2), 1000BaseX (SFP) WS-X45-SUP6-E JAE151008BZ
7 48 10/100BaseTX (RJ45)V, Cisco/IEEE WS-X4248-RJ45V JAE15140BE0
8 48 10/100BaseTX (RJ45)V, Cisco/IEEE WS-X4248-RJ45V JAE151100XK
9 48 10/100BaseTX (RJ45)V, Cisco/IEEE WS-X4248-RJ45V JAE15140BH2
Paul
Hi Paul,
On a 4510R-E 10 slot chassis, the 1050 W per slot maximum only applies to slots 1 and 2; slots 3, 4,7, 8, 9, and 10 can supply up to 750 W, providing up to 25 ports of 30 W PoE."
So it is advisable to use POE modules on slot 1 and 2.
Thanks & Regards,
Karthick Murugan
CCIE#39285
