05-30-2012 10:03 AM - edited 03-07-2019 06:59 AM
Hey Guys,
I have 10 new AIR-CAP3502I-A-K9 connected to a WS-C3750X-48PF-L switch. 8 of the APs power on and connect perfectly, but two are problematic.
Both devices are granted power, but they never go past the stage of getting power from the switch. A look at POE shows:
Interface Admin Oper Power Device Class Max
(Watts)
Gi1/0/1 auto on 15.4 AIR-CAP3502I-A-K9 3 30.0
Gi1/0/2 auto on 15.4 AIR-CAP3502I-A-K9 3 30.0
Gi1/0/3 auto on 15.4 AIR-CAP3502I-A-K9 3 30.0
Gi1/0/4 auto on 15.4 Ieee PD 3 30.0
Where the AP that is not working is connected to Gi1/0/4. The interface shows down/down. I've tried shutting the interface, removing power, cdp etc.
Are there any other tricks you can think of to get it working or would you say that it's 2 faulty APs? I am not based at site unfortunately so I cannot console to the APs and check them out.
Thanks for any help!
05-30-2012 03:43 PM
Yes. I've seen this issue very, very often. I'm suspecting it's a cabling issue. And there is a "trick" to find out. Here are the command combination needed to be entered on the 3750X:
1. Command: test cable tdr interface Gi1/0/4;
2. Wait for approximately 5 to 7 seconds;
3. Command: sh cable tdr interface Gi1/0/4; and
4. Kindly post the output.
05-31-2012 02:09 AM
Hey, thanks for your reply. Output is as follows:
Interface Speed Local pair Pair length Remote pair Pair status
Gi1/0/4 auto Pair A N/A N/A Normal
Pair B 37 +/- 10 meters N/A Open
Pair C 37 +/- 10 meters N/A Short
Pair D N/A N/A Normal
I take it this means that there's an issue with some of the pairs? I'll get the cables swapped. Thanks!
05-31-2012 03:18 PM
Yes. It means that the cable directly connected to the switch is faulty.
If you want to read a "lay man's" document about TDR, try this link here.
Get the cables swapped and run the test again. What you want to see under Pair Status are (for all four pairs) "NORMAL".
06-02-2012 04:59 AM
Hey man, thanks a lot for your help!
06-02-2012 06:02 PM
Thanks for the ratings Andrew. I presume the cable swap rectified the issue?
