PoE not working on a specific port
coreacorea
when plugging a cisco 7060 to the specific switchport it does not power on.  The inline power consumption is abnormally high compared to the other phones that are plugged in, maybe double the amount.
non poe devices work on the same port.
I used multiple cables and phones
6 Replies 6
glen.grant
  Check the power budget on the switch and see if the switch has any more power available to assign to that device. It is also possible that the switch cannot support that high a class of device if its more than 15.4 watts .
also check if PoE is enabled on that port.
Best Regards
Please rate all helpful posts and close solved questions
Best Regards Please rate all helpful posts and close solved questions
poe is set to auto
there is enough power available available.
we have 3 model phones-the 7975 consume the most power, for some reason the 7960 model consumes more power than the color phones
Could you post output of #show power inline, thanks.
Best Regards
when plugging a phone the ps from and to are double the amount compared to the same models that are plugged in.  Getting a replacement blade.  Thanks for all the input
