07-19-2016 06:57 AM - edited 03-08-2019 06:41 AM
I have a quick question on Point to Point connection.
I have a corporate office with a 4506 for now and a new L3 core coming soon. It is connected with a dedicated 1GB link to a Data Center at a remote location that has a Nexus 3048 as the L3 switch there. Is there any reason to put routers in-place to handle the point to point or just let it ride between the 2 L3 switches?
Solved! Go to Solution.
07-19-2016 07:30 AM
I have a quick question on Point to Point connection.I have a corporate office with a 4506 for now and a new L3 core coming soon. It is connected with a dedicated 1GB link to a Data Center at a remote location that has a Nexus 3048 as the L3 switch there. Is there any reason to put routers in-place to handle the point to point or just let it ride between the 2 L3 switches?
Hi ,
Its all depends on your design, how you want this office to be connected either as L2 or L3 .
You can terminate the link on 4506 switch and can have L3 communication between remote and datacenter and can do static routing between two locations.
Hope it Helps..
-GI
07-19-2016 07:30 AM
Hi ,
Hope it Helps..
-GI
