Switching
Labels
Hello, Cisco Community!I’m really happy to share that I’ll be hosting the Cisco Community Lab Series, a brand-new hands-on learning journey designed to help you build practical networking skills step by step.Every Thursday at 8 PM EST, I’ll post a ne...
testing tls1.3 for http and tacacs services on 9300-48U with 17.15.3 http is fine but I don't see tls option under tacacs server config switch(config-server-tacacs)#t?timeout any advice is appreciated, I have my root and signed certificate associated...
ammahend by VIP Alumni
  • 311 Views
  • 9 replies
Spoiler (Highlight to read)Spoiler (Highlight to read)Spoiler (Highlight to read)    Hi, "I am experiencing an issue using the backspace key while performing a configuration process. The key is unresponsive, preventing me from correcting any config...
I have unexpected behavior from connected field devices.  For redundancy, there are field devices that have two Ethernet ports and act as bridges.  One port will be to my 9300 switch, second port to another field device, and daisy chain maybe two-fiv...
Ruhtra by Level 1
  • 524 Views
  • 10 replies
  • 1 Helpful votes
Hello Together,we have a Catalyst 9500 Core Switch and I wan to Isolate a specified VLAN (VLAN 5) deny to connect to all other VLAN. Here is a simple configuration and explanation what the result should be.VLAN 2 (Server) 10.1.2.0/24 Gateway VLAN int...
ralpho1 by Level 1
  • 451 Views
  • 4 replies
Hello Cisco Community!One virtual gateway. Zero downtime. That’s the power of First Hop Redundancy Protocols (FHRP)!In this week’s session, I break down HSRP, VRRP, and GLBP, showing how they keep your network’s default gateway always available, prov...
Please wait while the system restarts.Initializing Hardware...System Bootstrap, Version 17.8.1r[FC2], RELEASE SOFTWARE (P)Compiled Wed 01/26/2022 11:22:44.16 by relCurrent ROMMON image : PrimaryLast reset cause : SoftwareReloadC9300L-48T-4X platform ...
Hi,I am tshooting this. there is a port-channel with two physical ports configured on cisco core mode LACP active and the other side which is fortigate also configured with LACP active. was working fine and recently cisco keeps reporting one port ( s...
