Highlighted
Beginner
point- to – point local E-line
I want to build an point- to – point local E-line carrier Ethernet services between IOS XRv routers using the link bundles. Once the two local EFPs linked with a point-to-point cross connect, the state of the cross-connect becomes up. But still the ping between CEs failed. what could be the problem?
Below are the output details of IOS XRv router confgiuration,
PE1:
RP/0/RP0/CPU0:PE1#sh run | begin xconnect
Tue Jan 16 18:26:15.215 UTC
Building configuration...
xconnect group test
p2p test1
interface Bundle-Ether100
interface Bundle-Ether101
RP/0/RP0/CPU0:PE1#sh run int bundle-ether 100
Tue Jan 16 18:28:23.989 UTC
l2transport
RP/0/RP0/CPU0:PE1#sh run int bundle-ether 101
Tue Jan 16 18:28:27.894 UTC
l2transport
CE1:
ipv4 address 10.10.10.1 255.255.255.0
interface GigabitEthernet0/0/0/3
bundle id 100 mode on
interface GigabitEthernet0/0/0/4
CE2:
ipv4 address 10.10.10.2 255.255.255.0
interface GigabitEthernet0/0/0/5
bundle id 101 mode on
interface GigabitEthernet0/0/0/6
0 REPLIES 0
Content for Community-Ad
