Policy Map issue
ruliffilur
I got a 2960 switch that iam trying to apply the fallowing policy map to the output of an interface, then i get the fallowing error: Switch(config-if)#service-policy output test
police command is not supported for this interface
Configuration failed!
Warning: Assigning a policy map to the output side of an interface not suppor
ted
here is the policy map it self:
policy-map test
class class-default
police 15000000 1000000 exceed-action drop
if I set this policy as input it works fine, but why is not outsut supported? Do I need a better IOS or doesnt this platform support output policy at all?
//Rulif
mohammedmahmoud
Level 11
Level 11
AFAIK you can only attach inbound policy-maps to the 2960 switch ports.
HTH, please do rate all helpful replies,
Mohammed Mahmoud.
mohammedmahmoud
Level 11
Level 11
Mohammed Mahmoud.
many thanks!
//Rulif
