port adapter gigabit router 7204vxr npe-400
victors0991
Hi, I want to find a gigabit port adapter to my router. I found pa-ge port adpater but this port is for fiber link and I want a gigaport adapter for copper not fiber and I do not find that. Anyone knows a gigabit port for copper?
8 Replies 8
Reza Sharifi
NPE-400 does not support Gig ports.  You need NPE-G1 or G2.
And is there  any requirement to change the processor of the rputet?
I think, it is cheaper to get a router with NPE-G1 or G2 instead of changing the IO card and at the end it may not even work.
But is my router 7204xvr soport npe-g1?
Yes and no.
Yes, your router can support GigabitEthernet (if you don't exceed your bandwidth points).  The question you'd like to ask is "Can my router PUSH 1 Gbps both ways (in and out)?".  Sadly, the answer is "barely".
But I do not understand, Do gigabit port consume bandwidth point? I thought that It not consume bandwidth
Not the port.  The line card.  Every line card of the 7200 (including VXR) has bandwidth points.
Again, that's not the argument.  If you happen to find a GigabitEthernet for the router, the router WILL NOT be able to support 1 Gbps speed.   So it's a futile attempt, not to mention, a waste of fine good money.
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
BTW, often "fiber" (e.g. SFP) ports support copper modules.
As others have noted, a NPE-400 is rather underpowered to support gig ports.  (Wirespeed gig, for minimum sized Ethernet, in just one direction, requires up to 1.488 Mpps, or about 3 Mpps for full duplex.  Consider a NPE-400 offers 400 Kpps, a NPE-G1 1 Mbps, a NPE-G2 2 Mpps, and a NSE-1 3.5 Mpps.)
