Port Channel 3750 X
lcarbajalparedes
Beginner
Beginner
I would like to know how many port channel can i canofigured in the switch 3750 X ? and if there is a limitation by IOS ?
4 REPLIES 4
lessaid.a
Beginner
Beginner
You can have 48 Portchannel on the switch.
You can put 16 ports on a portchannel, but only 8 will be active on the same time.
Best regards,
Leo Laohoo
VIP Community Legend VIP Community Legend
Limitation is not by IOS but by IEEE standard.
hipolitor1
Beginner
Beginner
I've been getting the following error after the 3rd port channel in a 3750:
Gi1/0/4 err-disabled
Is this what you were experiencing, if the answer is yes how did you fix it
Leo Laohoo
What did the logs say?  What is the output to the command "sh interface status err"?
Most of the time, an interface of a port channel goes into error-disable if the configuration are NOT the same as the rest of the port-channel members.  For example, the channel members may have VLAN 3,4,5 as allowed VLAN but you have an interface with only 3,4.
