Port-channel between 3750 and 2960
remarkit
I have plugged 2 UTP 1Gb cable on 2 ports of a 3750 switch and 2 ports of a 2960 switch.
I am trying to trunk the 2 switches with a port-channel, but something seems off in my configs since the port-channel reports a speed of 1000Mb/s when I wass expecting 2000Mb/s
Config on Switch1
interface Port-channel1
switchport mode trunk
interface GigabitEthernet1/0/11
description -empty-
channel-group 1 mode on
interface GigabitEthernet1/0/12
description Trunk port to 10.1.255.100 port 24
Some more info
Switch1#show interfaces port-channel 1
Port-channel1 is up, line protocol is up (connected)
Hardware is EtherChannel, address is d4a0.2ab7.b48c (bia d4a0.2ab7.b48c)
MTU 1500 bytes, BW 2000000 Kbit, DLY 10 usec,
reliability 255/255, txload 1/255, rxload 0/255
Keepalive set (10 sec)
Full-duplex, 1000Mb/s, link type is auto, media type is unknown
input flow-control is off, output flow-control is unsupported
Members in this channel: Gi1/0/11 Gi1/0/12
Last input 00:00:00, output 00:00:00, output hang never
Queueing strategy: fifo
Output queue: 0/0 (size/max)
12227738 packets input, 2355872064 bytes, 0 no buffer
Received 115654 broadcasts (114816 multicasts)
0 watchdog, 114816 multicast, 0 pause input
30714069 packets output, 25032340084 bytes, 0 underruns
0 output errors, 0 collisions, 1 interface resets
Switch1#show etherchannel
Channel-group listing:
Group: 1
Group state = L2
Ports: 2 Maxports = 8
Port-channels: 1 Max Port-channels = 1
Protocol: -
Minimum Links: 0
Config on Switch2
interface GigabitEthernet1/0/23
interface GigabitEthernet1/0/24
description Trunk Port to Stack Master's port 12
Some more info:
Switch2#show int port-channel 1
Hardware is EtherChannel, address is 00cc.fc21.7e98 (bia 00cc.fc21.7e98)
MTU 1500 bytes, BW 2000000 Kbit/sec, DLY 10 usec,
Members in this channel: Gi1/0/23 Gi1/0/24
Last input 19:36:42, output 00:00:00, output hang never
Output queue: 0/40 (size/max)
5 minute input rate 58000 bits/sec, 106 packets/sec
5 minute output rate 4000 bits/sec, 5 packets/sec
30728351 packets input, 25033314906 bytes, 0 no buffer
Received 7136969 broadcasts (626201 multicasts)
0 watchdog, 626201 multicast, 0 pause input
12226992 packets output, 2355786810 bytes, 0 underruns
0 unknown protocol drops
0 lost carrier, 0 no carrier, 0 pause output
Switch2#show etherchannel
Group: 1
Group state = L2
Protocol: -
Minimum Links: 0
Can someone help me get it right?
Thank you
Reza Sharifi
The numbers are correct. Look at the bandwidth, which is 2Gig.
BW 2000000 Kbit,
Reza Sharifi
BW 2000000 Kbit,
Joseph W. Doherty
BTW, don't forget, any single flow will still be limited to 1 gig.
