Port Channel Cisco 6500 Series
How much is the limit for the creation of PortChanel in a Core Switch 6509 and 6513?
Is there a limitation byu hardware?
7 Replies 7
Ryan Curry
Are you asking how many ports are allowed in a port channel?  If so, 8 is the max and they must all be of the same type (speed, duplex, etc.) and configuration (i.e. trunk or access as well as allowed VLANs).  Hope that helps.
vmiller
Level 7
Level 7
For IOS12.2.18 you can create a maximum of 128 etherchannels, subject to the constraints listed above.
For CATos  I bleieve ther is a limitation in some chassis to 63.
Is it the same limitation for the Nexus 7000 Series.?
Well, there you go, it's not the first time I've been wrong ...
I think vmiller was talking about No. of EtherChannels and you were talking about No. of ports in an Etherchannel... Both are different and you were not wrong AFAIK.
-Vijay
Jovan Bogoev
Beware of trying to port-channel interfaces across different line cards. The QoS scheduling can be different and not allow a port-channel to come up. See the difference below:
sh int te7/12 cap
TenGigabitEthernet7/12
  Model:                 WS-X6716-10GE
  Type:                  10Gbase-SR
  Speed:                 10000
  Duplex:                full
  Trunk encap. type:     802.1Q
  Trunk mode:            on,off,desirable,nonegotiate
  Channel:               yes
  Broadcast suppression: percentage(0-100)
  Flowcontrol:           rx-(off,on),tx-(off,on)
  Membership:            static
  Fast Start:            yes
  QOS scheduling:        rx-(1p7q2t), tx-(1p7q4t)
  QOS queueing mode:     rx-(cos,dscp), tx-(cos,dscp)
  CoS rewrite:           yes
  ToS rewrite:           yes
  Inline power:          no
  Inline power policing: no
  SPAN:                  source/destination
  UDLD                   yes
  Link Debounce:         yes
  Link Debounce Time:    yes
  Ports-in-ASIC (Sub-port ASIC) : 9-16 (9-12)
  Remote switch uplink:  no
  Dot1x:                 yes
  Port-Security:         yes
sh int te6/1 cap
TenGigabitEthernet6/1
  Model:                 WS-X6708-10GE
  Type:                  10Gbase-SR
  Speed:                 10000
  Duplex:                full
  Trunk encap. type:     802.1Q,ISL
  Channel:               yes
  Membership:            static
  Fast Start:            yes
QOS scheduling:        rx-(8q4t), tx-(1p7q4t)
  CoS rewrite:           yes
  ToS rewrite:           yes
  Inline power:          no
  UDLD                   yes
  Link Debounce:         yes
  Ports-in-ASIC (Sub-port ASIC) : 1,4-5,7 (1)
  Dot1x:                 yes
  Port-Security:         yes
This is the error you will see:
%EC-SP-5-CANNOT_BUNDLE2: Te7/12 is not compatible with Te6/1 and will be suspended (qos-card types of Te7/12 do not match Te6/1)
Enter the command below on the port-channel to allow the grouping of the ports
#no mls qos channel-consistency
That being said I hope I can bundle interfaces of different optic types i.e. 10Gbase-SR and 10Gbase-LRM
