Port-Channel drops traffic temporarily when 1 port goes down
jclj
Hello, I have a lab environment with a layer 3 (3850) switch that has a port-channel with a layer 2 4506. What i'm seeing in the logs is a port drops off, then users come over saying they have lost their remote session into the lab:
Sep 25 09:46:22: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/3, changed state to up
Sep 25 10:28:51: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/3, changed state to down
Sep 25 10:28:58: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/3, changed state to up
My config on the 3850 is:
interface GigabitEthernet1/0/3
 switchport mode trunk
 channel-group 2 mode active
end
Lab#sho run int gi 1/0/4
Building configuration...
Current configuration : 90 bytes
interface GigabitEthernet1/0/4
end
and on the 4506:
interface GigabitEthernet2/1
 logging event link-status
 logging event trunk-status
end
4506swa-04#sho run int gi 2/2
Current configuration : 181 bytes
interface GigabitEthernet2/2
end
The network outage is minimal, but enough to kill the remote sessions. I have replaced the cable and there are no errors on the interfaces. Why is there an outage with a 2 port channel when 1 port goes down?
Thanks for any advice.
on a side note, you might want to try and configure:
no port-channel standalone-disable
on your port channel interfaces (if your IOS supports it). This basically prevents the entire channel from going down when one side becomes unresponsive...
7 Replies 7
Hello
Are both physcail interfaces in a up/up state?
Have you tried changing the cabling/ports and recreating the PC .
Can you post -
Show etherchannel summary
show etherchannel port-channel
res
Paul
res
Paul
Kind Regards
Paul
balsamovan
Try changing the negotiation protocol used for establishing the port-channel.
In your case you are using LACP as indicated by the word "active" at the end of "channel-group 2 mode active"
Try using PaGP (Cisco Proprietary) - keyword is "desirable"
If this doesn't improve things, turn off negotiation protocol altogether by using keyword "on".
Also, perform a "shutdown" on the interface before changing the ocnfiguration, this tends to flush out any errors and such, once you're happy, issue a "no shutdown" to bring it back up.
Best of luck, keep us posted.
jclj
Show Etherchannel Summary on 4506:
Number of channel-groups in use: 2
Number of aggregators:           2
Group  Port-channel  Protocol    Ports
1      Po1(SD)          -
2      Po2(SU)         LACP      Gi2/1(P)    Gi2/2(P)
 Channel-group listing:
Group: 1
                Port-channels in the group:
Port-channel: Po1
Age of the Port-channel   = 313d:22h:43m:01s
Logical slot/port   = 11/1          Number of ports = 0
GC                  = 0x00000000
Port state          = Port-channel Ag-Not-Inuse
Protocol            =    -
Port security       = Disabled
Group: 2
Port-channel: Po2    (Primary Aggregator)
Age of the Port-channel   = 313d:22h:43m:04s
Logical slot/port   = 11/2          Number of ports = 2
Port state          = Port-channel Ag-Inuse
Protocol            =   LACP
Ports in the Port-channel:
Index   Load   Port     EC state        No of bits
  1     00     Gi2/1    Active             0
  0     00     Gi2/2    Active             0
Time since last port bundled:    0d:08h:14m:16s    Gi2/1
Time since last port Un-bundled: 0d:08h:14m:23s    Gi2/1
Show Etherchannel Summary on 3850:
1      Po1(RU)         LACP      Gi1/0/1(P)  Gi1/0/2(P)
2      Po2(SU)         LACP      Gi1/0/3(P)  Gi1/0/4(P)
show etherchannel port-channel on 3850:
Group: 1
Port-channel: Po1    (Primary Aggregator)
Age of the Port-channel   = 44d:22h:47m:50s
Logical slot/port   = 12/1          Number of ports = 2
HotStandBy port = null
Passive port list   = Gi1/0/1 Gi1/0/2
Port state          = Port-channel L3-Ag Ag-Inuse
Protocol            =   LACP
  0     00     Gi1/0/1  Active             0
  0     00     Gi1/0/2  Active             0
Time since last port bundled:    44d:22h:22m:18s    Gi1/0/2
Time since last port Un-bundled: 44d:22h:40m:41s    Gi1/0/1
Group: 2
Logical slot/port   = 12/2          Number of ports = 2
Protocol            =   LACP
  0     00     Gi1/0/3  Active             0
  0     00     Gi1/0/4  Active             0
Time since last port bundled:    0d:08h:16m:42s    Gi1/0/4
Time since last port Un-bundled: 0d:08h:16m:46s    Gi1/0/4
Julio E. Moisa
Your configuration looks fine, have you tried to replace the SFP (if apply) also check the speed and duplex. Or try to use other ports.
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
jclj
The Duplex and Speed look good. They are copper cables. I can try and use a different port and see if that helps.
jclj
This command:
does seem to keep the port-channel up. Thanks! Now i just need to see why the interface is getting over subscribed.
Thanks for the help
