07-29-2015 09:53 AM - edited 03-08-2019 01:10 AM
Hello, I have a bunch of port-channels that have 4 interfaces linked to them.
Why is it that only 2 of interfaces show a "30 second output rate 0 bits/sec, 0 packets/sec" under "show interface" and have normal input rates.
is this something with the port-channel configurations that makes 2 of the interface not output traffic.
These are the 4 interfaces in the pagp port-channel:
Switch1#sh int t1/1/6
30 second input rate 317000 bits/sec, 169 packets/sec
30 second output rate 38090000 bits/sec, 5616 packets/sec
Switch1#sh int t1/1/5
30 second input rate 1846000 bits/sec, 880 packets/sec
30 second output rate 25927000 bits/sec, 4325 packets/sec
Switch1#sh int t2/1/5
30 second input rate 515000 bits/sec, 237 packets/sec
Switch1#sh int t2/1/6
30 second input rate 14208000 bits/sec, 2423 packets/sec
These are the counters:
Switch1#sh int t2/1/5 counter
Port InBytes InUcastPkts InMcastPkts InBcastPkts
Te2/1/5 9887096678034 37586027362 12091339 48982047
Port OutBytes OutUcastPkts OutMcastPkts OutBcastPkts
Te2/1/5 11429315477991 12179268874 3550021 1114871
Switch1#sh int t2/1/6 counter
Te2/1/6 16307118524351 50713982712 15148528 63558571
Te2/1/6 4156839382844 5679773089 5987049 7680701
Switch1#sh int t1/1/6 counter
Te1/1/6 10034774352417 39653084589 18145803 38882592
Te1/1/6 189372703971619 174906765970 3266534 6687054
Switch1#sh int t1/1/5 counter
Te1/1/5 13966434357936 49859031974 33541931 73303464
Te1/1/5 196915105905576 176988906709 221324366 47603699
Thanks in advance and let me know if you need more info
Solved! Go to Solution.
07-29-2015 12:17 PM
I'd agree with Madhu that it looks as if the load balancing is not that efficient.
And to add to what he's already included, you can determine the current port-channel load balancing mechanism using the show etherchannel load-balance command, and can change it using the port-channel load-balance <mode> command in global configuration.
To achieve good load balancing you ideally want to use source and destination addresses, and include MAC, IP and TCP/UDP port if supported by the platform.
Note also that the balancing used by one partner is totally independent of the balancing of the other partner. To ensure you achieve good balancing in both directions you would need to check both switches.
07-29-2015 10:03 AM
It could be due to port-channel load balancing. Please note that the when you add more than 1 interface to a port-channel, it does not mean you are going to load balance the traffic. Every time a traffic flow comes to the switch needing to go out of Port-channel, it calculate the hash and then selects one of the link, so for example if you have 2 ports in one PO, and have only 1 flow passing through, effectively it will use only 1 link.
Hope this helps,
Madhu
** Please rate useful Posts**
07-29-2015 12:17 PM
