Port Channel producing slow results
jmalge
Hello all. I'm having an issue with a port channel.  This port channel is set up for a NAS device and the server group is complainging that it's taking too long for their backup to run.  I verified in Orion that the ports in the etherchannel are only receiving 1.4 mbps of data.  Other port channels are as much as 500+ mbps.
We are looking for differences in the port channels but are having issues coming across them.  I thought I would give everyone here a shot at it.  Here is the configs and other results below.
FR0001#show etherchannel 353 det
Group state = L2
Ports: 2   Maxports = 16
Port-channels: 1 Max Port-channels = 16
Protocol:   LACP
Minimum Links: 0
                Ports in the group:
Port: Gi1/1/3
Port state    = Up Mstr In-Bndl
Channel group = 353         Mode = Passive      Gcchange = -
Port-channel  = Po353       GC   =   -         Pseudo port-channel = Po353
Port index    = 0           Load = 0xFF        Protocol =   LACP
Flags:  S - Device is sending Slow LACPDUs   F - Device is sending fast LACPDUs.
        A - Device is in active mode.        P - Device is in passive mode.
Local information:
                            LACP port     Admin     Oper    Port        Port
Port      Flags   State     Priority      Key       Key     Number      State
Gi1/1/3   SP      bndl      32768         0x161     0x161   0x1104      0x3C
Partner's information:
          Partner Partner   LACP Partner  Partner   Partner  Partner     Partner
Port      Flags   State     Port Priority Admin Key Oper Key Port Number Port State
Gi1/1/3   SA      bndl      255           0x0       0x11     0x1         0x3D
Age of the port in the current state: 667d:20h:09m:45s
Port: Gi2/1/3
Port index    = 1           Load = 0xFF        Protocol =   LACP
Local information:
Gi2/1/3   SP      bndl      32768         0x161     0x161   0x2104      0x3C
Gi2/1/3   SA      bndl      255           0x0       0x11     0x2         0x3D
Age of the port in the current state: 667d:20h:10m:27s
                Port-channels in the group:
Port-channel: Po353    (Primary Aggregator)
Age of the Port-channel   = 24d:05h:26m:35s
Logical slot/port   = 46/28          Number of ports = 2
HotStandBy port = null
Port state          = Port-channel Ag-Inuse
Protocol            =   LACP
Fast-switchover     = disabled
Load share deferral = disabled
Ports in the Port-channel:
Index   Load      Port          EC state       No of bits
0      FF        Gi1/1/3            Passive   8
1      FF        Gi2/1/3            Passive   8
Time since last port bundled:    20d:03h:36m:36s    Gi2/1/3
Time since last port Un-bundled: 20d:04h:58m:37s    Gi2/4/17
Last applied Hash Distribution Algorithm: Fixed
FR0001#show run int po353
Building configuration...
Current configuration : 97 bytes
interface Port-channel353
description Tier 3 Storage
switchport
switchport mode access
end
FR0001#show run int gi1/1/3
Current configuration : 134 bytes
interface GigabitEthernet1/1/3
switchport
channel-group 353 mode passive
end
FR0001#show run int gi2/1/3
interface GigabitEthernet2/1/3
switchport
end
From show etherhchannel summary detail
353    Po353(SU)       LACP      Gi1/1/3(P)     Gi2/1/3(P)
I appreciate your help.
6 Replies 6
hello
how did you create the port channel?
i mean did you let the router/switch create it when the interfaces were configured?
try and delte the port channel
conf t
no int port 353
delete your physical interface
default int ran gig1/1/1 ,gig2/1/1
recreate the interfaces and assign
channel-group xxx mode active
channel protocol lacp
once this is done your port-channel will be created automatically
res
Paul
Sent from Cisco Technical Support Android App
Kind Regards
Paul
I created the port channel manually which I had done several times in the past. This is the first instance where we have actually seen poor performance.
I'm going to try this and see how it works.
Hello Jason,
I have found in the past some etherchannel issues have a rose from manually creation of the port-channel,
Configuring the physical interfaces ( routed/switched/access) into an ehterchannel and then letting the router/switch create the port-channel seems to provide a much cleaner and less problematic aggregate link.
res
Paul
Please don't forget to rate any posts that have been helpful.
Thanks.
Kind Regards
Paul
Leo Laohoo
Can you please post the output to the commands "sh interface "?
If this is a 3750-series please add the following commands "sh controll util" and "sh controll e ".
FR0001#show int gi1/1/3
GigabitEthernet1/1/3 is up, line protocol is up (connected)
  Hardware is C6k 1000Mb 802.3, address is 0022.90fb.751a (bia 0022.90fb.751a)
  Description: Tier 3 Storage
  MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
  Keepalive set (10 sec)
  Full-duplex, 1000Mb/s, media type is 10/100/1000BaseT
  input flow-control is off, output flow-control is on
  Clock mode is auto
  Last input never, output 00:00:17, output hang never
  Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 0
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute output rate 28000 bits/sec, 38 packets/sec
     284039399 packets input, 21227923238 bytes, 0 no buffer
     Received 119823 broadcasts (119807 multicasts)
     0 watchdog, 0 multicast, 0 pause input
     74298243 packets output, 7562800490 bytes, 0 underruns
     0 output errors, 0 collisions, 3 interface resets
FR0001#show int gi2/1/3
GigabitEthernet2/1/3 is up, line protocol is up (connected)
  Hardware is C6k 1000Mb 802.3, address is 0022.905c.9066 (bia 0022.905c.9066)
  Clock mode is auto
  Last input never, output 00:00:36, output hang never
  Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 9
  5 minute output rate 118000 bits/sec, 111 packets/sec
     397607 packets input, 51395008 bytes, 0 no buffer
     Received 72259 broadcasts (61506 multicasts)
     2358686042 packets output, 3285777351338 bytes, 0 underruns
     0 output errors, 0 collisions, 6 interface resets
I don't see anything wrong with the above output.
Do an extended (and continous) ping from the host to host and see what the results are.
