port config down stream switches dual home nexus VPC
hmc250000
In a dual homed topology as in this image should the ports on the switches FXE-01 and FXE-02 connecting to vPC101 and vPC102 be configured with LACP? Would regular stand alone ports work?
Would this be different if you use Catalyst switches downstream?
Sorry for late reply But I was busy,
no different Still you need to be sure that NSK is support this design "please recheck the doc. above".
balaji.bandi
i would advise LACP port-channel (since they are dual homed)
FEX is just line card extention, so Port-channel is good for redundency.
BB
