11-19-2015 06:51 AM - edited 03-08-2019 02:46 AM
is there a method to control the error-disabled ports in trhe switch cisco (script...)
thanks
11-19-2015 07:03 AM
Hello
can you elaborate?
res
Paul
11-19-2015 09:23 AM
11-19-2015 11:28 AM
Hello
Yes you can - you can set error- recovery, it will attempt to recovery a error-disabled port after a certain amount of time specifed by the intervall value you set.
Show errdisable recovery
Error recovery cause
Error recovery intervall
res
Paul
11-19-2015 11:16 AM
Hello ,
Check out the below link for recover a port from err-disable state.
http://www.cisco.com/c/en/us/support/docs/lan-switching/spanning-tree-protocol/69980-errdisable-recovery.html
Hope it Helps..
-GI
Rate if it Helps..
