Port forward
dejanlesnik
I have cisco 1800 router. On FE0 is my Internet connection with one static IP. On the inside is my local network in witch is one server. I forwarded some ports to this server and it works when I'm connecting from outside. But when I'm trying to connect to this server thru outside IP address, connection is closed. I can not connect to the server from local network using domain name.
How can I fix this?
Thank you
Dejan
cadet alain
use NAT NVI:
-replace ip nat inside and ip nat outside commands by ip nat enable on both interfaces
-replace ip nat inside command vy ip nat command without the inside keyword
-disable ip redirect on both interfaces with no ip redirect command
Alain
cadet alain
use NAT NVI:
Alain
