Port forwarding con be config on cisco 3750 Switch
Srinivas N
Beginner
Beginner
Dear Friends,
I have a 3750 catlyst switch in my network and it is like a distubation switch,
And for the nating and dhcp nomadix is using as gateway in the same network.
for one of my local PC i need to config the port forwarding in 3750 switch.
Is it posible ?
Plz help me how to config the port forwarding on 3750 switch,
Srinivas. N.
Thanks & Regards, Srinivas. N.
cadet alain
Mentor
Mentor
3750 doesn't support NAT so no port forwarding possible on this platform.
Regards.
Alain
Hi Cadet alain,
Thanks for is there any other way ?
Srinivas. N
yes do it on the device doing NAT.
Regards.
Alain
Recognize Your Peers
