Port is down between two 3550s
David Lin
Beginner
Beginner
I am trying to setup trunk between two 3550s. I configured the trunk one each switch as usual but the port always show interface is down and notconnected (The cable is good).
The IOS version is 12.1(22)EA1a.
interface FastEthernet0/24
switchport mode trunk
Switch#sh int f0/24
FastEthernet0/24 is down, line protocol is down (notconnect)
  Hardware is Fast Ethernet, address is 000e.84f6.3618 (bia 000e.84f6.3618)
  MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
  Keepalive set (10 sec)
  Auto-duplex, Auto-speed, media type is 100BaseTX
  input flow-control is off, output flow-control is unsupported
  Last input never, output 00:10:55, output hang never
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
I was thinking on trunk encapsulation and tried both dot1q and isl were all not working. I even removed the trunk setting and put them on same VLAN, the ports still show down and notconnected. This is weird to me. When I connected any one of 3550 with other device like ASA5520 with trunk setting, it works fine.
Is there special setting for configuring trunk between 3550s?
Thank you in advance.
djh278778
Beginner
Beginner
Here is a stupid question but is sometimes overlooked, are you using a crossover cable?
Of cause not crossed cable as I mentioned the cable is correct otherwise I won't ask this stupid question
Switch <-> Switch you need a Xover cable unless the switches have Auto-MDIX support (which I don't recall being supported on
3550s)
Switch <-> ASA a regular cable will work.
Do yourself a favor and get a Xover cable.
Edison.
OMG, never pay attention on that. Auto-adapt has been implemented to most of ethernet cards in last decade.
Anyway, let me try cross cable thgouh. Thanks a lot.
Recognize Your Peers
