05-06-2014 01:37 AM - edited 03-07-2019 07:20 PM
Dear All,
I have 4506 with WS-X4648-RJ45V+E. If I connect the cable on one port it is showing down down and on PC it is limited connectivity.
Please suggest.
Cisco IOS Software, IOS-XE Software, Catalyst 4500 L3 Switch Software (cat4500e-UNIVERSALK9-M), Version 03.02.00.XO RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2011 by Cisco Systems, Inc.
Compiled Thu 22-Sep-11 20:42 by prod_rel_team
Cisco IOS-XE software, Copyright (c) 2005-2010 by cisco Systems, Inc.
All rights reserved. Certain components of Cisco IOS-XE software are
licensed under the GNU General Public License ("GPL") Version 2.0. The
software code licensed under GPL Version 2.0 is free software that comes
with ABSOLUTELY NO WARRANTY. You can redistribute and/or modify such
GPL code under the terms of GPL Version 2.0. For more details, see the
documentation or "License Notice" file accompanying the IOS-XE software,
or the applicable URL provided on the flyer accompanying the IOS-XE
software.
Image text-base: 0x100A12B4, data-base: 0x13F29B60
ROM: 15.0(1r)SG3
Jawa Revision 7, Winter Revision 0x0.0x3
DLD-03-4506 uptime is 10 weeks, 2 days, 2 hours, 47 minutes
Running default software
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
License Information for 'WS-X45-SUP7L-E'
License Level: lanbase Type: Permanent
Next reboot license Level: lanbase
cisco WS-C4506-E (MPC8572) processor (revision 4) with 2097152K/20480K bytes of memory.
Processor board ID SPE1625010J
MPC8572 CPU at 1.5GHz, Supervisor 7L-E
Last reset from PowerUp
2 Virtual Ethernet interfaces
244 Gigabit Ethernet interfaces
2 Ten Gigabit Ethernet interfaces
511K bytes of non-volatile configuration memory.
Configuration register is 0x2101
Thank You,
Abhisar.
05-06-2014 03:12 AM
I am not sure if IOS 3.2.0 will enable 46XX line card the option of TDR. Try this:
05-06-2014 12:03 PM
Dear Leo,
Thank you for your reply. I will post it soon.
Thank You,
Abhisar.
05-18-2014 11:32 AM
Dear Leo,
TAC has suggested to upgrade IOS because of BUG.
https://tools.cisco.com/bugsearch/bug/CSCsv15915/?reffering_site=dumpcr
Thank You,
Abhisar.
05-18-2014 04:34 PM
Thanks for this info but your line card is NOT running on the IOS code specified in the BTK.
05-08-2014 04:05 AM
Dear Leo,
I tried the test cable command but it is not available for this version. I have already opened TAC case, will let you know the update. I feel its issue with version 3.2.0, may be need to upgrade.
Thank You,
Abhisar.
