Port mirroring
vinothlb1
I m using Catalyst 2900 series xl IOS Version 12.0(5)WC8.. How to configure port mirroring on this switch.. Pls help..
5 Replies 5
srinivas_816
Can you try
conf t
int fast 0/X
port monitor Fast 0/y
how to check port monitor working or not?
raj_ctech
you have to configure SPAN/RSPAN feature in your switch.you can get the document on cisco site.
or tell me full setup where you want to mirror ur traffic.
Raj
You can configure SPAN for the monitoring the traffic on to the switch port
http://www.cisco.com/en/US/docs/switches/lan/catalyst2900xl_3500xl/release12.0_5_wc_1_/swg/swgports.html
Further to discussion attached is the configuration and monitoring example
Switch-A# configure terminal
Switch-A(config)# monitor session 1 source interface fastEthernet0/2 both
Switch-A(config)# monitor session 1 destination interface fastEthernet0/3
Switch-A(config)# exit
Switch-A# show monitor
Session 1
Type : Local Session
Source Ports :
Both : Fa0/2
Destination Ports : Fa0/3
Encapsulation: Native
Ingress: Disabled
