Port Mirroring
edbadmin1
Hi all,
I have a cisco 6509 series and would like to configure port mirroring from the cisco 6509 to another cisco 3750 switch.
Any ideas ?
I tried the set span and it din work.
Thanks...
bvsnarayana03
Level 5
Level 5
As far as I know, port mirroring can be done only when both src & dst ports are on same device.
guruprasadr
Level 7
Level 7
HI, [Pls Rate if HELPS]
Source and Destination Interfaces should be on the same SWITCH.
You can configure 6 SPAN Session's per Switch.
Please see the attachment (.pdf) for how to configure the port mirroring feature on cisco devices.
PLS RATE if HELPS
Best Regards,
Guru Prasad R
