Port monitoring white shut
adnan.akbar
Hello ,
is it possible to shutdown a  specific port on my 3750x and monitor this port at the same time .
for example , im dealing with a mac authenticated network using port security , i want to shut down all the ports that are not used at the moment , however , if some one gets connected to the one of the shutdown ports  i want to know the mac address of the user or atleast to know that i have someone who is just plugged in to the one of the shutdowned ports .
thanks
Adnan
Isn't that the point of mac-authentication ie. they need to authenticate before they can use the network ?
If you want a further check then a simple solution is -
1) create new vlan for unused ports eg. vlan 998
2) allocate all unused ports into that vlan
3) make sure the vlan is only a L2 vlan
then a device can be connected, you can see the mac-address but they cannot go anywhere within your network because they cannot route to any other vlans.
You can then decide whether to move them to one of your routed vlans or not.
Jon
Jon Marshall
Adnan
Not as far as i know. A shutdown port will not come up if a device is connected and it certainly wouldn't learn the mac-address of the device.
What exactly is the problem you are trying to solve ?
Jon
i want the data to be resticted on a port so that no one connects to the network until registred in my database .
can have the port up but put a restiction on it not to send/recieve data ?
Adnan
Adnan
Jon
Thanks Jon
thats a great one .
cheers
Adnan
